Thread: Hello from SW Missouri
    Sep 2011
    Springfield, MO
    Hello all... I stumbled on this site and find it already helpful.
    I live in SW Missouri, Springfield to be exact, and we just moved into a home with a pool. I can't tell you much about it yet since I'm pretty much a pool virgin, but I'll learn soon enough.
    My wife and I moved here five years ago from Arkansas. I love to fly fish and therefore the handle "ArkieFlyGuy" fits. I also like to hunt, play guitar and mandolin, do woodworking, cook outdoors, tie my own flies, and write. I have a book published called "Dragonflies on my Rod Tip" about growing up and living in the Ozarks.
    My wife and I are really looking forward to enjoying the new pool, even though it will be limited this year. It's 102 here today, so at least ONE more dip will be nice...
    Look forward to learning from all of you and appreciate you being kind to a noob!!!
    17 x 32 feet in-ground - 22,500 gallons - Vinyl liner
    Haywood sand filter (Model TBD) - Pump (TBD)
    Hot Spring spa
    Total noob...
    msgtdan's Avatar
    Jul 2011
    SW MO
    Re: Hello from SW Missouri
    I work in Springfield and live in Buffalo. This site has helped me through my first summer with a pool without an algae bloom, very good advice here.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Butterfly's Avatar
    South Carolina
    Welcome to the forum
    You're done SLAMing when:
    Welcome to TFP. The water is fine!
    10,800 gallons Gunite/Plaster
    Hayward 244t 24" Sand Filter with Zeo
    1 1/2 HP Challenger
    Digital Pool Pilot DIG-220 SC-48
    Located in NOLA
