Thread: "Different" kind of return jet
    Sep 2011
    Springfield, MO
    34
    Hello all... We just purchased a house with an inground pool. First time to own a "real" pool (other than one of those "blow up" WalMart specials...) I'm sure I'll have lots of questions as I go and have already learned some things by reading the forums...
    Anyway, to my question...
    Our pool has two return jets on a separate line from the pump. They are mounted on either side of the steps. Each has a pair of ports, one below the surface and one above the surface. When they are activated, it appears the top ports draw air and help create a "jacuzzi" effect.
    The REAL question, however, is that they create a lot of noise when running like the noise when you turn on the tap at a sink and getting all the air out. Is this normal or is there something I can do to quiet these down? (I know... I know... keep 'em turned off... :P )
    It's 102 here in SW Missouri, so I'm going to go home and enjoy a cold beer in the middle of the pool...
    Thanks for your help...
    17 x 32 feet in-ground - 22,500 gallons - Vinyl liner
    Haywood sand filter (Model TBD) - Pump (TBD)
    Hot Spring spa
    Total noob...
    South Central NJ
    3,192
    Re: "Different" kind of return jet
    That is normal for these. The air drawn in adds pressure to increase it's massage effect. It also is useful for raising the pH.
    Scott
    Owner of - PoolGuyNJ LLC
    22,537
    You can plug the ports above the water line and that'll stop the air from getting sucked in and therefore stop the noise.
    Sep 2011
    Springfield, MO
    34
    Thanks guys... Good to know about the pH effect.
    Hot Spring spa
    Total noob...
