Results 1 to 8 of 8
Thread: Reviews of epool Game 4817 and other wireless temp monitors
    Hi all. I just joined; hope I'm doing this post right.
    I was considering the purchase of the wireless Game 4817 wireless monitor. Saw very bad reviews on this board, but all were several years old ~2009 or so. Called company and they admitted lots of problems with current model and they are going to come out with a re-engineered model in Spring 2012.
    One of the comments I read on that board was that there are several wireless water temperature monitors on the market but there were no references to companies or models available.
    Does any one have experience with such things and can offer one or two models?
    no-mas's Avatar
    Jun 2008
    FL
    405
    Re: Reviews of epool Game 4817 and other wireless temp monit
    I'm not sure what you're talking about. Can you post a link to the product?
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Here is a link to the product I was asking about:
    http://www.poolplaza.com/P-GAM-4817-5269.html
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Hopefully it will work well for you! A bunch of us tried a similar one a couple years ago, and I think water always ended up getting inside the floater and ruining it At least that's what happened with mine.
    Re: Reviews wireless temp monitors
    Yes they now put the (car wheel lug nut criss cross tightening procedure" into their set of "little" instructions. Next time I take it out of the water, I also plan to put some silicon grease on the gasket and cover assembly. Be sure to coat both sides of the gasket, i.e. get grease underneath it too. Silicon grease is available at plumbing shops and Hardware stores like Lowes, Home Depot, etc.....
    Oct 2009
    3,899
    Sounds familiar Good luck!
