Thread: Shocking and FC
    Shocking and FC
    I have been shocking my pool for over a week. I still am having 4-5 ppm chlorine loss overnight. I am getting tired of buying 12 bottles of bleach at a time. Shock level for our pool is 18. By morning I am down to 14 usually. Then I start the process over and add to get my level back up. Help! When is this going to stop?? Pool is crystal clear
    Currently
    FC 18
    CC 0.5
    Ph 7.5
    CYA 60
    brh
    18x36 25,000 gallon, vinyl liner, 1.5HP Super Hayward, Cartridge Filter
    step jets, 2 main drains and skimmer, we have a chlorinator
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Shocking and FC
    Try increasing your shock level to 24, based on the Chlorine/CYA Chart in Pool School.
    Also, have you brushed and checked behind light niches, ladders, and any sneaky place algae can hide?
    You're done SLAMing when:
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Re: Shocking and FC
    With a CYA of 60 your shock level is actually 24 ppm. But it sounds like you are close. When shocking you need to maintain the shock level consistently or it will take longer. After the FC drops below shock level for your CYA it is not as effective and takes longer. If you need to walk away try and get the FC higher than 24, say 30 so you have some buffer.
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    Apr 2011
    Lynchburg VA
    393
    Re: Shocking and FC
    I agree, bump your FC level a little over the shock level to give yourself some wiggle room. The harder you hit it and stay on top of it maintaining the shock level the faster the process will be. I went through the shock process earlier this year so a similar sized pool and it took over 2 weeks.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    May 2011
    Clearwater, FL.
    446
    Re: Shocking and FC
    Hi brh,
    My pool is way smaller, but was a mess when I started to clean it up the TFP way once I got my TF-100-XL kit.
    Some of my problems were from the stock small filter cartridge not getting clear, but a lot was when the FC was falling below my shock value while at long work days, 9-10 hours.
    One of the mods suggested to go 3 to 4 over my shock level to overcome my falling level when I was away.
    That did the trick in the next 2-3 days, with a filter sock over the bucket skimmer!
    Pool cleared right up and passed all 3 tests!
    Hope this might help you. Oh, I also was reminded to have some POP! (pool owner patience)
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
