Results 1 to 13 of 13
Thread: Where Does This Pipe Lead??
    Good morning all, does anybody know what this pipe might lead to (2nd from the left). It has some sort of check valve inline.
    The far left pipe runs to the pop ups. The 3rd pipe from the left runs to the returns (4 of them in the sides of the pool). The 4th pipe from the left is from the filter/pump. The 5th and 6th pipes from the left feed the two waterfalls.
    Any help would be appreciated.
    Thanks.
    [attachment=0:20df2q1t]Pool 20.JPG[/attachment:20df2q1t]
    22,542
    Re: Where Does This Pipe Lead??
    I'd call the builder and see if they have a layout of the plumbing at the pad.
    The house was built in 1993 and we've been in it about 2 years. There is no info on who built the pool.
    22,542
    Since there's no valve in it to isolate it, it's going to be almost impossible to tell where it goes. I assume the flow arrow on the check is pointed down.
    You could try putting a little 'party pool' coloring in the pump basket and see where all the color comes out at.
    Oct 2007
    Philadelphia, PA
    86
    Do you have a spa? It could be the return to the spa. Spa returns often have a check valve if the spa is higher than the pool. It is odd that there's no valve for this line.
    11x27 in ground, vinyl pool
    ~12,500 gal
    PAC FAB (Pentair) Pinnacle 3/4 hp pump
    Pentair 24 sq ft DE filter
    One skimmer, one return (no main drain)
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Since you are gonna cut it and install a valve anyway, you should be able to 'garden hose' test it to see where it goes. You WERE planning to install a valve there, right? <nudge-nudge><wink-wink>
    nutjob's Avatar
    May 2011
    Dallas
    109
    Spa fountain, perhaps? Our spa has a hole in the middle of the floor that we can insert an upright pipe into. The end of the pipe has a decorative diffuser. When we turn the valve at the pump it makes a pretty fountain in the middle of the spa.
    That we never otherwise use. ^_^
    I laugh—to disguise the tears.
    Size 15,000 gal 510′² | Filtration DE 48′² | Sanitation SWG+O₃ | Placement in-ground (IG) | Finish pebble
    Pumps Intelliflo VS+SVRS main WhisperFlo WF-28 feature | Location Dallas TX US (33ºN 97ºW)
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    I'm confused... Why do pool builders not put a sticker or some kind of identification on the pools they build so future new owners can use it properly? Or at least be contacted if the new owner needs service? Rarely does the original home owner remain the owner forever, everyone knows this. Residential pools seem to be the only product/construct that regularly comes without O&M's or even a marker of the builder/supplier's contact information. Huh???
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Apr 2010
    Buckeye, AZ 85326
    619
    What about a pressure side cleaner port?
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    No spa attached to the pool here. What is a pressure side cleaner port?
    By the way Shane 1, I'm in Avondale. It's hot as you know what isn't it.
    Apr 2010
    Buckeye, AZ 85326
    619
    Quote Originally Posted by twowhlrcr
    It is crazy hot lately! I got my pool temp down to 89 degrees today. It was pure heaven jumping in.
    Here are some posts on Pressure Side Cleaners. I doubt that is what its for but you never know. Since its on the same valve as the popups I would think its part of the cleaning system.
    search.php?keywords=pressure+side+cleaner&terms=all&author=& sc=1&sf=titleonly&sk=t&sd=d&sr=topics&st=0&ch=300&t=0&submit =Search
    2' Powerfall
    Looked up the manual for the Polaris Caretaker Popup system. Looks like it's a pressure relief valve for that system.
    Thanks anyways guys.
