Results 1 to 10 of 10
Thread: FC loss durring hot days
    I'm here in AZ (hot 110F), right now my CYA is about 35-40. Last night I put in bleach to the equivalent of 4ppm (I tested the levels). After the pool sits during the day I'm down to .5ppm FC. I have not seen any algae in my test at all. Should I raise my CYA? I feel like Im dumping in lots of bleach daily bi daily...
    11500 gallon pool
    all levels are good right about now.
    Well except my Calcium is high but that another topic...
    Cornerstone 18 x 36 Rectangle 22,000 gallons
    Hayward SS24T High Rate Pro Series Sand Filter
    Inground Vinyl Liner with Polymer Walls
    1.5hp 220 volt energy efficient High Performance Pump
    Intermatic swimming pool Timer TR104P3
    Aqua Genie Skimmer System (2)
    Hayward Color Logic light
    Liner: Oxford aquarius 28 MILL
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: FC loss durring hot days
    You've got it tough down there. Three thoughts:
    1. Cover the pool when you are not using it during the day with an uv opaque cover.
    2. Go to 8 ppm in the evening and check it in the morning to make sure it is above 7 ppm(used poolcalculator.com, 40 ppm CYA to get this value which is the top of the normal range). That should keep you higher, but may not be enough.
    3. Raise your CYA level to 50 ppm, and put your FC at 9 in the evenings and make sure it is at least above 8 ppm in the morning (again calculated using poolcalculator, 50 ppm CYA).
    Keep an eye on your pool...you might want to do a OCLT: http://www.troublefreepool.com/pool-...rnight_fc_test just in case you have organics gobbling up your FC without you knowing it
    ok cool, i just added a jug 182oz ill test b4 bed and in the morning, thanks again tfp!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    I add about 4ppm over my minimum FC# for my CYA level and it seems to work well in Texas. I'm trying to keep right at 50 CYA btw.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by the taxidermist
    Let us know the test numbers
    Well before I went to bed I was 8ppm on the nose (pool ran for about 4 hours after adding the bleach), woke up, tested a lil later than I would have liked, 830am... 3.5ppm
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    The good news is, you found out why your chlorine is dropping fast. The bad news is, you most likely have organisms (algae, etc.) eating it. It is time for the shocking process: http://www.troublefreepool.com/pool-...king_your_pool, remember it is a process and can take some time.
    Let us know if you have any questions!
    The thing is my CC is .5ppm and water is crystal clear! I can still have algae?
    Aug 2010
    Boston, MA
    176
    Yes. If your CCs outgas quickly enough (relative to the rate your FC oxidizes organics and produces them) you can have low CC even with an active bloom. And a low- to moderate-level bloom can frequently not be evident to the naked eye.
    On the bright side, catching a bloom before it becomes visible means that there's less algae and it accordingly takes less bleach to kill it off.
    20k gallon IGP
    Plaster over gunite
    3/4 hp Hayward pump
    Purex Triton DE filter
    TF100 test kit w/ speedstir
    awesome, off to buy some bleach!
