Thread: Same water different readings
    Feb 2011
    Central Texas
    187
    I bought a FAS/DPD refill for my TF-100 kit. I took chlorine readings with the old bottle of drops and got a reading of 3FC. Took it with the new drops and got a reading of 5FC. Re-ran the tests again with no change. Which one is right?
    IG 23K Gal, Quad DE 80, PebbleSheen, Intelliflo VS+SVRS, MT 400 NG, Stenner Pump
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: Same water different readings
    Go with the new stuff. If new reagents are different, obviously the old stuff is bad.
    Which is weird... since there was a recent report about old reagents testing 2-3 times high. I'd think old/bad reagents would test low like you're seeing vs testing very high personally.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by frogabog
    I don't know what the answer is, but I would think old reagents would give you a false high since common logic would say they are weaker....therefore taking more drops. Guess it depends on what happens to them as they break down, and this is probably a bad place for common logic to apply. Whatever the answer, I'd go with the new reagent result. Besides...what are you going to be adjusting by from here on anyhow?
    I would be curious too though and just happen to have some old and new. I'll be comparing this weekend to see what I get. In the end, two PPM isn't that big a deal if it's a 10 mL test to me.
    Essential Links:
    Feb 2011
    Central Texas
    187
    Could the new stuff have been sitting on the shelf for a long time? Maybe one possibility. I might order another bottle and see if they are the same. Or another possibility is that the old bottle has a defective dropper size?
    30,431
    The R-0871 is light sensitive which is why it's in the opaque bottle. I'm not sure if that's helpful, though, because I don't know what happens after it has been exposed to light.
    Virtually none of the chemistry we have sits for more than 30 days and it has a promised shelf life of one year from Taylor. My instinct says go with the newer but I don't think this issue has been reported before so I am not sure of the cause.
    Feb 2011
    Central Texas
    187
    Well, I store it in a kitchen cabinet under the counter, so light should not be the issue.
