Thread: IntelliChlor IC40
    IntelliChlor IC40
    We recently purchased a home that has a salt water pool. We are very good about taking our water to get tested at our local pool store to find out which chemicals need to be added, etc. About 2 days ago, we noticed that none of the lights were on while the pump was running. The guy at the pool store suggested that we poor acid through the pump to clean it out & then replace it & see if that would work. That didn't work, so then we checked the fuse in the power center box & that fuse was old & no longer working, so we then replaced it. Now, after doing all that the box is still not lighting up & when I powered my pumps back on after replacing the fuse .. a burnt smell, along with a little bit of smoke & some brown thick liquid substance bubbled up from the top (on the side of where the lights on the box) came out of the intellichlor ic40. What is going on!? Has anyone ever had this problem?? In case I do need to replace my IC40 .. where can I get a good deal on it?? Thanks!
    Pool Info:
    Gallons: 14,300
    Dimensions: 16x32
    24K gal, vinyl, Hayward S244T sand filter, Dolphin Dynamic cleaning robot
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: IntelliChlor IC40
    did you pour un-diluted acid through it? and where exactly was it poured, through the swg cell or the pool pump?
    Yes we tried pouring acid, etc. We ended up calling a local pool company & they said it was a goner :/. We ended up having to purchase a new one .
