View Poll Results: which test kit is the best?
Voters
30. You may not vote on this poll
  • TF -100
    20 66.67%
  • Leslies test kit
    1 3.33%
  • Taylor 2006
    9 30.00%
Results 1 to 10 of 10
Thread: what is your favorite test kit? and what do you recommended?
    Arch_2_Wifey's Avatar
    Aug 2011
    CALIFORNIA
    23
    Which test kit would you recommend for me? I have an intex agp 18' x 52" approx 7,000 gallons and im currently using the index sand filter model sf15110....but interested in adding an swcg and possible hard plumbing
    SOUTHERN CALIFORNIA POOLS RULE!! <3
    New to tfp and loving it!!! ;-)
    Intex round ultra frame AGP 18' x 52" (6,981 gl.)
    intex sand filter Model SF15110 Sand Filter (1600 GPH)
    Learning the bbb way & Interested in hard plumbing my system.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,098
    Re: what is your favorite test kit? and what do you recommen
    I've used the TF-100 ever since I switched from Baquacil to Chlorine and it by far has been a lifesaver. The only pool store for me is over 20 miles away, so using them is out. I HATE test strips as I never seem to match the color....let alone get the same answer twice from either the strips or the stores.
    The TF-100 has all the "tools" you will need to manage your pool, as well as is backed by the site. The members here on the board know the kit inside and out, let alone support from the company itself on the board.
    For $80 you'll get at least two years worth of accurate testing, plus a sparkling pool.
    Sep 2010
    Noblesville, IN
    104
    I have three words for this....Support the site.
    16 x 32 15300 gal. IG Vinyl Jandy pump, Jandy sand filter, Paramount circulation system, Automatic pool cover.
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    The only two I would consider are the TF-100 as already stated and the Taylor K-2006.
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    Quote Originally Posted by Arch_2_Wifey
    I went for the TFT-100 XL and the speed stir. The xl because sooner or later I will need it and will save me shipping and waiting time. The speedstir because you don't have to stop and swirl between each drop. It is $30 I think, if money is an issue you can do without it. But I am not sorry I bought it. It has a light that shines up into the sample so you can see the color well and you never have to stop and swirl.
    If money is really tight you can buy the tft-50 but I think the 100 is the way to go.
    On the SWG I think you can get it cheap from walmart right now. Someone who knows the details can fill you in.
    10,800 gallons Gunite/Plaster
    Hayward 244t 24" Sand Filter with Zeo
    1 1/2 HP Challenger
    Digital Pool Pilot DIG-220 SC-48
    Located in NOLA
    Aug 2011
    CALIFORNIA
    23
    Thanks you guys
    Jun 2011
    Cape Girardeau, Mo
    125
    Taylor K-2006 or TF-100 both are equal in quality and accuracy and the key to a sparkling pool.
    Steve Frakes
    15' X 48'' Intex Metal Frame
    Intex Sand Filter 16'' 2650 GPH
    Taylor K-2006 Test Kit
    BBB and Borated
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Ditto. There are only a couple of kits with the tests necessary to really manage a pool, and they are the K-2006 and TF-100. Both use Taylor reagents, both have what you need. The TF-100 was custom assembled w/ Taylor tests for the TFP site to better accommodate the testing we need. Those of us that have purchased it are overwhelmingly pleased with it, but if you prefer to get a regular Taylor kit, the K-2006 will work for you.
    The real trick is to get a FAS-DPD test for free chlorine.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    The main reason the TF100 is a better value than the Taylor K-2006 is the bottle sizes and the great amount of CYA reagent in the TF100.
    The K-2006 also has unnecessary acid and base demand reagents. The pool calculator handles all chemical calculations for us. As such, these reagents often will go unused.
    From the http://tftestkits.net website:
    The Taylor K-2206 kit is a good choice if you have a pool that is already well-managed. It contains all the tests you need to keep your pool sparkling.
    If your pool has some water quality issues, we think the TF-100 makes more sense. It contains more reagents to perform many more tests for Chlorine and CYA...........very helpful for getting your pool in balance.
    Consult the information below to compare kits. NOTE - The acid and base demand tests in the Taylor K-2006 are fine tests but seldom used for residential testing. Most pool owners use a The Pool Calculator for the same results.
    ........................Taylor K-2006..........................TFTestkits TF-100
    pH ------------------ .75 oz .............................................. .75 oz
    FAS/DPD
    Chlorine Test ---------- .75 oz. .............................................. 2 oz.
    Total Alkalinity---------.75 oz ................................................. 1 oz
    OTO Chlorine Test------- no ....................................................yes
    Calcium Hardness
    Test ------------------- .75 oz ..................................................1 oz
    CYA test-------------------- 1.5 oz ............................................ 8 oz.
    Base Demand Test-------- yes ..................................................... no
    Acid Demand Test -------- yes ..................................................... no
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    May 2011
    Clearwater, FL.
    446
    If you live in the U.S., Get the TF-100 hands down!
    Better value, Very well thought out and designed for us to follow the pool school format, Dave and Meg are great to work with as they are very hard working couple to take care of our needs with prompt shipping and helps support this site!
    What more do you need to know?
    Chuck
    P.S. This is a favorite link too:
    http://www.troublefreepool.com/click...rter-t183.html
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
