Results 1 to 17 of 17
Thread: DIg starts tomorrow! Yikes!
    Aug 2011
    North Fort Worth, TX
    131
    Our PB and diggers will be here bright and early tomorrow and suddenly I am researching like crazy to make sure I have all my t's crossed and i's dotted! What are your key elements that I need to make sure we have?
    Built in 2011, 23x34' IG freeform play pool (18,850 gallon) ~ 7' spa raised 18" with 5 jets, 3 tier fountain and 5 tier cascading waterfall into pool ~ IntelliChlor SCG ~ Pentair Intelligent VS-3050 variable speed pump ~ Clean and Clear 420 cartridge filter ~ Easy touch controller ~ Blue Granite Pebble Sheen ~ Intellibrite LEDs ~ Turbo twister slide ~ 8x8 flagstone tanning ledge with umbrella sleeve and bubbler ~ In-pool flagstone table with umbrella sleeve ~ 997 sq ft exposed aggregate decking Our pool build
    shcuck's Avatar
    Aug 2011
    Frisco, Tx
    113
    Re: DIg starts tomorrow! Yikes!
    Good luck and congrats on the project start.
    I too am in a similar boat, where we might start the dig next week, and have NO CLUE what to expect, other than I hope there are no major setbacks and issues
    Keep us posted on your progress.
    New pool owner ~ 30x17' IG Gunite freeform ~3' - 5.6' - 4' play pool (15,000 gallon) ~93' Perimeter ~432 sq ft~ 7' spa raised 12" with 6 jets, overflow waterfall and Bubbler with 100w light~24" sheen spillway ~ ic40 SWG ~ Pentair Intelliflo SVRS VS-3050 variable speed pump ~ 520 cartridge filter ~ Suntouch FOB Key controller ~ 500w Lighting~ 400,000 BTU Pentair Heater ~ Freeze Sensor ~ 350 sq ft tan color textured concrete decking My pool Build thread
    Enjoy the ride! Expect the unexpected. Ask 1000s of questions. Double check what the pool contractor tells you since they make can make mistakes too. Get to know the subs and talk with excavator and shell contractors to double verify location, size, and elevations. Mistakes here have domino-like side effects. Get to know your plumber and don't let him leave without fully understanding, or at least documenting, your plumbing design. Take lots of pictures. Prepare for ups and downs and just enjoy the finished product.
    Good luck!
    Shelley
    Denver, CO
    Aug 2011
    DFW
    1
    Congratulations!
    I'm on the down hill side of my build.........plaster goes on tomorrow. As mentioned, don't be shy with the questions or the subcontractors. If you see something out of place, say something to your PB. This site is also a great source of information with a large group of pool owners who are more than willing to answer questions.
    The one bit of advice I would give you is to water the gunite shell several times each day after the installation. With the extremely dry, hot weather we have been experiencing, concrete can develop small (hairline) cracks that are merely cosmetic in nature, but I'm a stickler for details. I'm sure your PB will give you some instructions on this, but I watered at least 3 times a day for 5 days.
    Good luck.
    Keep a pair of boots out. The first thing they make is a mess. I hope you have an enjoyable ride.
    10,800 gallons Gunite/Plaster
    Hayward 244t 24" Sand Filter with Zeo
    1 1/2 HP Challenger
    Digital Pool Pilot DIG-220 SC-48
    Located in NOLA
    May 2011
    Montgomery, TX
    176
    do a bucket test before you issue the last check.
    nutjob's Avatar
    May 2011
    Dallas
    109
    I found that tipping contractors with cases of beer helpful. ^_^
    I laugh—to disguise the tears.
    Size 15,000 gal 510′² | Filtration DE 48′² | Sanitation SWG+O₃ | Placement in-ground (IG) | Finish pebble
    Pumps Intelliflo VS+SVRS main WhisperFlo WF-28 feature | Location Dallas TX US (33ºN 97ºW)
    Aug 2011
    131
    Thank you for the tips! The dig started early this morning and so far is making good progress. I started a new thread to document the build! What is the bucket test?
    Jun 2011
    Frisco, Texas
    70
    Monkey's Mom- do you mind sharing what builder you decided to use?
    33'x21' In-ground (23,000 gal) - 8' spa raised 18" with 8 jets | Filtration Jandy DE 60 | Sanitation Aquapure 1400 SWG | Pumps Intelliflo VS+SVRS 3.0HP & Jandy 1.5HP stealth water feature pump | Heating Jandy LRZ400 | Lighting Jandy LED Spa (1)/Pool (2) | Coping Tennessee Crab Orchard & Moss Rock | Finish pebble sheen type (riversand) Tahoe Blue
    Aug 2011
    131
    It's Paul Miller Custom Pools... Tell em Kristy sent ya
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I believe they mean a leak test. Fill a bucket, set it in the pool on a step, wait a day, if the water in the pool drops faster than the water in the bucket you have a leak and they need to fix it before you pay the final check.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Aug 2011
    131
    Thanks msgtdan, I will make sure we do a leak test before issuing the final check
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    On the trash and mess issue, I found if I got a bunch of 5 gallon buckets and labelled them trash, and put out a couple of big cans with contractor duty liners in them, everyone uses them! Helps keep the mess to a minimum and sets a tone of professionalism on the job. Makes it easy to clean up too when there are plenty of receptacles around.
    I actually had one guy thank me for putting them out.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    When I have subs coming I also put out an ice chest with half water and half Gatorade in bottles labelled "contractor/subs drinks" and it really makes em friendly. Especially with this hot summer.
    shcuck's Avatar
    Aug 2011
    Frisco, Tx
    113
    Quote Originally Posted by Lershac
    This is a great idea that does not cost much and really makes a difference from a friendliness perspective. Will keep this in mind when I start mine.
    Aug 2011
    131
    Great ideas Lershac! We had our 4 year old pass out gatorade to the workers today so he could be part of the pool team! He loved it and the workers seemed to appreciate it too
    Sep 2009
    Frederick County, MD
    184
    We put out water, and other drinks + bought lunch (pizza / subs / McD's), even made a birthday cake for one of the guys on the dig crew. We typically only had 2 or 3 guys at a time, so all told, maybe $100 or so. The guys who dug for the shell sent us a handwritten thank you note.
    Well worth it as far as I can see. In fact, we treat all trades who do extensive work at our house like this.
    Jim
    Southern Frederick County, MD - Leisure Moroccan 38 Fiberglass Pool - 19,800 gallons
    Pentair 1.5 hp 2 speed pump - Cartridge filter - Dolphin robot - TF-100 Test Kit - SWCG
