Results 1 to 11 of 11
Thread: algae
    algae
    Had an issue with green pool. Found you site followed your advise and treated with bleach. Maintainedc a fc of 7 - 10 for full day treated again this am now count to high to read and the water is still green. What would be the next step
    [center]tktbull 18000 gal pool sand filter ag pool
    22,551
    Re: algae
    Read the article on how to shock and you need a good kit to ensure you're really at shock level for your CYA.
    Do you know what your CYA is?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: algae
    It would be helpful if you could post a full set of test results to include:
    FC
    CC
    pH
    TA
    CYA
    CH
    You're done SLAMing when:
    Re: algae
    We have had this pool for about 2 months and was told the only tests we neededwas for cl ph and alkaline. Guess I need to get a better test kit and get this thing under control
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: algae
    Quote Originally Posted by tktbull
    Yep, you will not regret it. It will save you money and time!
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: algae
    And answer all your questions about your pool. If we can answer them from afar with only test results... imagine what you can do right there by your own pool!
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: algae
    You can take a water sample to a pool store and have it tested. Post the results back in this thread.
    Pool store testing is hit/miss, but we should be able to get enough info to at least get you started.
    Having a good test kit will put you in control of your water. The fav around here is the TF100. Link in my sig.
    What size/pounds is the sand filter?
    Welcome to the forum
    Re: algae
    So, here are my levels... I can see the bottom, but is is still pretty cloudy... How long should I keep it at that level?
    FC - 10
    CC - 0
    pH - 7.2
    TA - 180
    CYA - 25
    CH - 40
    -9000 Plaster IGP and attached spa with 4 jets , Hayward H400IDL NG heater, Hayward swimclear 4025 cart filter, Hayward superII 2hp pump, Goldline controls ps-8 controler with T-cell 15, Caretaker 99 in-floor cleaner and polaris in-ground leafetrapper.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: algae
    Hey knightrider, make sure you read/reread http://www.troublefreepool.com/pool-...king_your_pool its a process and can take some time. For your CYA of 40 ppm, poolcalculator.com is giving a suggested minimum shock level of 15 ppm, so to do the shocking process correctly, get your FC above that and keep it there until you pass the three criteria in the shocking process (also in my sig). You can use poolcalculator to calculate how much bleach/liquid chlorine to add.
    Re: algae
    Thank you! I did miss it...
    Re: algae
    Thank you! I did miss it...Although it was 25, which is why it does seem to be clearing albeit slower than I'd like...
