Thread: Using Taylor's R-0867 Deox reagent in a K-2005 kit
    New here! First post! I hope someone can help me.
    We've got the Taylor K-2005 "Complete" test kit (rebranded by Leslie's Pools) that utilizes the DPD test kit for FC and TC.
    I want to shock our pool using monopersulfate, but its clear that MPS can interfere with the TC reagent, giving an artificially high reading. Taylor sells a "Deox Reagent" (R-0867) that removes MPS interference from the DPD test. What I *cannot* find are instructions to use it with the K-2005 kit. e.g. How many drops of R-0867 to add and when during the test?
    For the record, I went by our local Leslie's looking for the reagent and help on the topic, but they hadn't even heard of the reagent before...
    Thanks!
    Re: Using Taylor's R-0867 Deox reagent in a K-2005 kit
    http://www.taylortechnologies.com/produ ... umber=5807
    http://www.taylortechnologies.com/produ ... KitID=2266
    Also, if you buy reagent R-0870 and R-0871, then you can do an FAS-DPD chlorine test in the comparator test tube that comes with the K-2005.
    Just fill the large tube to the 10 ml line, add two scoops of R-0870 powder and then add R-0871 drop-by drop counting the drops until the pink color clears. Multiply the number of drops by 0.5 ppm to get the FC reading.
    Then add 5 drops of R-0003 (which comes in the K2005). If the pink color returns, add R-0871 drop-by drop counting the drops until the pink color clears again. Multiply the number of drops by 0.5 ppm to get the CC reading.
    Support the site
    Aug 2010
    Boston, MA
    176
    What's the reason for wanting to use the MPS?
    20k gallon IGP
    Plaster over gunite
    3/4 hp Hayward pump
    Purex Triton DE filter
    TF100 test kit w/ speedstir
    Quote Originally Posted by Beamup
    Multiple reasons. Primarily because we want to be able to swim in the pool 1-2 hours after shocking. I also want to avoid Cal-Hypo since our CH is very, very high.
    22,553
    So you're not really shocking. You're just throwing something in there to raise the FC a little while. You really need to read the pool school article on shocking. If you need to shock, you really don't need to swim in and hour or two after first starting it. You've just began to kill whatever is in there and one application doesn't make it sanitary.
    Will do, thanks!
