Thread: hot tub aerator
    hot tub aerator
    I have ben using bleach in my watkins hot tub for about 4 years now. I would like to do away with the aerator in the hot tub. My question is can I just unplug aerator unit or do I need to remove and plug air lines also?
    Thanks Ric
    Ric W
    My Pool
    8605 gal fiberglass, 3/4 hp pump, sand filter, aquabot cleaner, heat siphon heat pump, tiger river(sumatran) spa
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    Re: hot tub aerator
    Just curious, why do you want to remove it? pH rise? If you do remove it, my thought is it is probably best to plug, so stuff can't grow in it easily where the flow is low.
