Thread: Where to get a replacement pump motor?
    Aug 2007
    west tx
    7
    We had 2 big dust storms this week, so I figured that I better brush the 1" of dirt that sits at the bottom and run the pump for a couple of days. We had the pump motor running on filter for 3 or 4 days. Turned it off to change to backwash and then restart the motor. The motor did not start turning but rather it made a load humming noise. I thought something was in the pump section so I removed the motor. The pump was not full of garbage and I can easily turn the shaft of the motor. The motor makes the same sound when I run it with it removed from the pump. So, I am guessing the motor has partially failed.
    My motor is a Century Centerion by A. O. Smith. It is about 7 years old.
    The motor catalog number: B853
    Type: CX Frame: P56Y
    HP: 1.0 SF: 1.24 Phase: 1
    60 Hz, 3450 RPM
    Volts: 230/115
    Amps : sp 7.1 / 14.2
    Time: Continous Encl: DP Frame KJM
    Code: J insul class: B Ambient: 50 deg C
    Where can I get a new motor without paying the large mark up from the typical pool warehouses?
    Paul
    Always said I'd never have a pool, now I wouldn't be without one.
    There are some good deals available on the Internet is you do some searching.
    The starter contacts might be stuck. Sometimes giving the motor a solid bump, say with a 2x4 enough to shake things up but not enough to dent anything, can unstick the contacts. Or if you are feeling a little adventurous, you can try opening the motor up and cleaning and wiggling the contacts.
    Round Rock, TX
    529
    I just went through this a couple months ago.
    You can start here at the AO Smith cross reference webpage:
    http://www.aosmithmotors.com/concertox/ ... rence.html
    Put in your model number and it will tell you what motors to replace it with.
    I then found mine online and bought it here:
    A1 Pool
    http://www.A1PoolParts.com
    I bought the CSCR or energy efficient model as the cost was not that much more and there is a 25% reduction in electrical usage.
    Linky to my thread:
    http://www.troublefreepools.com/about3225.html
    Hope this helps,
    dave
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    If you have not replaced that motor yet, the most common issue with a spinning shaft and hum is a bad capacitor.
    Authorized IntelliFlo Installer
    Feb 2008
    Miami, FL
    38
    When I bought my house the previous owner showed me the well pump and how he was able to get around the humming problem. There was a slot in the far (outside) end of the pump shaft that could accomodate a large standard screwdriver. He had taken a flat spade-type wood drill bit, removed the protruding tip and then used it to kick-start the pump on startup. He would have his wife stand inside and kick the circuit breaker while he applied the drill power.
    As soon as I moved in, I replaced the capacitor which I was also told was the most likely cause (it's also one of the cheapest to fix). NOTE: IF YOU DON'T KNOW ANYTHING ABOUT CAPACITORS HAVE A PROFESSIONAL DO THE WORK. That didn't fix the problem so I removed the pump and took it in for repair. It turned out that the shaft was bent and the bearings shot so I scrapped it for a new one.
    18,000 gallon 17 x 35 in-ground diamond brite, Fafco solar, SWG, Barracuda G3, well pump - Biscayne Aquifer CH=250
    30,400
    Sounds like that has the potential to be the punch line of a "You might be a redneck" joke!!
