Results 1 to 9 of 9
Thread: Should I go with pool without main drain?
    Aug 2011
    Mechanicsburg, PA
    40
    One of the PB we are thinking to go with to build vinyl pool is going to put return at the deap end but said he did not do main drains for 20 years. No need to.
    Do i have to have one? What do you guys say?
    I guess small debries will collect at the bottom until i vacume. is there anything else?
    Or should I just tell him to put it in?
    IG double roman vinyl 40x20. 35000 gal. 9' deep. Diving board.Pentair 400HD gas heater, ItelliFlow Variable Flow pump, 520 cartridge filter, two pentair G5 lights, IC60 SWG cell.
    Photo album: http://slava.no-ip.org/~poolpic/photo
    22,553
    Re: Should I go with pool without mail drain?
    A lot of people are going without main drains. A lot of people that have main drains have trouble with them clogging. The call is yours but I'd say go without it. A low wall drain would be a nice replacement.
    WestSidePool's Avatar
    Cincinnati, OH
    424
    My pool was installed w/o a main drain. We haven't had any problems and it's one less thing to worry about having issues with.
    The one thing i could see using it for is draining the pool when getting it ready for winter. So I just bought a submersible pump to drain the water below the return jets.
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    Apr 2011
    Lynchburg VA
    393
    Re: Should I go with pool without main drain?
    My pool has a main drain but I have to admit I like the idea of no main drain and a low wall drain. You never really need the main drain to totally empty a pool and lets face it, if you pool really left filled with debris for whatever reason the main drain is going to be the first thing to clog up.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    mas985's Avatar
    Pleasanton, CA
    11,741
    If you do go without a main drain and you have a deep end, then I would have at least one lower return.
    Main drains really don't do much for that anyway. They can only suck in debris from a few inches away. They are primarily for circulation which a lower return can handle.
    Mark
    An automatic cleaner will take care of debris, help circulate bottom water and mostly make a main drain redundant.
    Support the site
    Aug 2011
    Mechanicsburg, PA
    40
    thank you guys.
    that reasures me with the PB selection. Some of the BS so much you can not tell truth from lies.
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    My pool has a main drain. It doesn't really collect anything. But then again don't expect to collect any debris, small or otherwise. Its real benefit is to provide additional circulation. You want to eliminate low/no circulation areas. I like Mark's idea of a deeper return(s).
    Mark, wouldn't loosing one suction side device (the main drain) negatively effect your plumbing efficiency? I know in that work sheet you made, asks for the number of suction side connections to determine head.
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    mas985's Avatar
    Pleasanton, CA
    11,741
    Yes, eliminating the main drain increases suction head some but one could always add a skimmer instead or even upsize the skimmer pipe one size. Either would help compensate some.
    Mark
