Thread: More pump problems - Cuts off after a minute and runs hot
    I installed my new pump about a month ago. yesterday I walk outside and the pump is making a very low hum and not doing anything. It is extremely hot to the touch. Once it has cooled for a little while, you can turn it on and it will pump and move water and then cut off within a minute. The pump shuts down and maintains a low hum. I'm trying to go through and check the resistance on the capacitors and such, but I'm not having much luck tracking down the problem. I'll have to get in touch with Hayward for warranty work possibly, but I'd like to have an idea of what is going on. Any direction on where to start?
    24,000 G, Sand, IG, Vinyl
    Re: More pump problems - Cuts off after a minute and runs ho
    Check the supply voltage and make sure that the pump is wired correctly for that voltage.
    Support the site
    carlos31820's Avatar
    Nov 2010
    Midland, Georgia
    353
    Yup... what he said. My pump did this when first installed because the electrician didn't wire the pump for 120v. Pump came wired for 220v by default.
    16x36 Vinyl Pool - 22.5K gallons.
    Jandy Stealth 1hp pump - Jandy CS-150 filter
    Jandy Legacy 250k heater - Jandy Ei SWCG
    Jandy Watercolors LED light
    Paramount Vanquish in-floor cleaner
