Results 1 to 7 of 7
Thread: Landscaping help around AGP...suggestions ?
    Jul 2011
    Lehigh Valley, PA
    163
    So I currently have a 2-3 foot ring around my AGP and at the point in the picture its a foot drop off from grass to dirt. I was going to fill it in with river rocks but was concerned about the pressure of the rocks on the pool wall. Any suggestions ?
    [attachment=0:240rkzn4]pool.jpg[/attachment:240rkzn4]
    21' All Steel AGP with Resin caps, Heyward S244T Sand Filter, Heyward 1HP 2 speed pump
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Re: Landscaping help around AGP...suggestions ?
    I had about a 2 ft drop on one side of my above ground pool. Heres what I did, laid a corrigated drain pipe down, filled the hole witk big rocks an concrete chunks from a broken up sidewalk, and then poured mulch over top of that. It's been 4 years with no issues. I laid the rocks and and stuff carefully so not to damage the side of the pool. So if you are using river rock, I really don't see a problem if you do it carefully.
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    Jul 2011
    Lehigh Valley, PA
    163
    Quote Originally Posted by pepsiholic
    By corrugated drain pipe you mean the black tubes ? You filled those with rocks ?
    Apr 2011
    Lynchburg VA
    393
    I think they placed the pipe in the area around the pool and then covered the pipe with rocks/concrete chunks and then mulched over that.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Jul 2011
    Lehigh Valley, PA
    163
    guess Im having a hard time envisioning putting round tubes of pipe with rocks on top of it and how that would protect the pool wall.
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    The pipe was for water drainage, to keep water from sitting next to the pool walls, then that was covered with the rock and such. Then a thin layer of mulch, but pea gravel or river rock would be just fine.
    [attachment=0:1qtuql01]pool.bmp[/attachment:1qtuql01]
    Jul 2011
    Lehigh Valley, PA
    163
    OK revisiting this now. So I am assuming the corrugated pipe that is around the pool is perforated ?
    So here would be my understanding of what to do.
    Put down a base of gravel all around pool.
    Put perforated corrugated pipe on the deeper side. Cover with gravel. Add river rocks on top of gravel. Does this make sense ? Will gravel get inside of a perforated corrugated pipe ?
    Is it ok for tiny pieces to get in but still allow water flow towards the back of the backyard? (my drain area)
