Results 1 to 11 of 11
Thread: Pump Replacement Advice Needed
    Aug 2011
    Central Florida
    87
    Glad I found this forum. I'm a bit of a junky when it comes to special interest forums.
    My pool is a 16x32 rectangle built in the early 1980's, and I live in Central Florida. Estimated volume is 21,000 gallons. Currently it is a hodge-podge of equipment. The motor has become really loud and I knew it was getting close to its demise. A couple of days ago a crack appeared in the pump on the veloute(sp?) near the metal band. I tried using JB Weld but it did not hold.
    One issue I have is 1.5" plumbing. I was looking at the Hayward Super Pump but realized it is 2" longer/deeper, and I would have to modify all the plumbing. The Pentair Whisperflo is roughly the same size as what I have now. First question - any preference between these 2?
    I also included a picture of the label from my pathetic motor. From the research I have done, it appears to be a 1HP with a service factor of 1.25.
    I could use all the advice I can get and really appreciate all the expertise here. One issue I have not looked into is energy efficiency. Being in Central FL this thing runs year round, 10-12 hours a day in the summer. If there is any additional info I can provide please ask. I'll check back frequently. Thanks.
    19K gallon rectangular, uncovered. Polaris 280 Hayward DE3620 Filter. Taylor k2006
    Aug 2011
    Central Florida
    87
    Re: Pump Replacement Advice Needed
    Here is a little more info about our pool. The distance from the pump to the far end of the pool is right at 50' and there are 4 returns. Pool capacity is roughly 20k gallons. Our power cost is $.145/kwh including taxes. I'll have to check the size of the Hayward cartridge filter.
    22,537
    I'd go with the Whisperflo and in a 2-speed model to match what you have now.
    Aug 2011
    Central Florida
    87
    Hey Bama - thanks for the reply. The more I read the more the math makes sense. It appears the 1.5" piping is the limiting factor in how much water can move through the system. I'm trying to determine the approprate HP for the new pump. I've tried to determine the existing motor HP, and the best I can make out is 1HP with a 1.25SF for brake HP of 1.25. Does this make sense? I have not priced the 2 speed pumps yet. If I do stick with 1 speed, how would I determine the correct HP motor? I think I have most of the info, pipe size, gallons, head feet, etc.
    22,537
    It's a 1 hp 1.25 sf, 56 frame motor. Match that (or close) and you'll be fine. You can get an idea of hp from the volts and amps.
    Aug 2011
    Central Florida
    87
    I'm looking at the Pentair Whisperflo WFDS-24 2 speed. The only question I have is the 2" ports. How do I match this up with my 1.5" pipes? Is it simply a matter of installing an adapter?
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    Yes, you can adapt up to the 2" from your 1.5" piping. If you have a good plumbing store near you you can get threaded ones (or other specialty adapters).
    Thanks for the pics I'd suggest putting unions on the influent and effluent pipes from the pump, it'll make working on the pump a LOT easier in the future While you're working on the plumbing, you might want to think about raising your cart filter up so that it's at ~ the same height as the 90 coming off the pump - you can also make the pump to filter 2". If you'll post a pic that shows all the above ground plumbing, we might be able to make a few suggestions on 'optimizing' your system.
    Luv& Luk
    -Ted
    Aug 2011
    Central Florida
    87
    Thanks Waste. I'll take a better picture of the area when I get home. I'm trying to determine the payback period for the 2 speed WFDS-24 over the single speed WF-24. The cost difference is around $200 from what I see.
    Aug 2011
    Central Florida
    87
    Below is a different view of the equipment.
    To save a few bucks short term, I'm now leaning towards the "energy efficient" WFE-3 and WFE-24. These are marketed as 3/4 and 1 HP, but after taking into account the SF, they both come out to 1.25 SFHP. I'm finding the WFE-3 a little cheaper online. Is there any reason to favor one of these over the other?
    Also, raising the filter was mentioned. Is it simply a matter of building a platform to bring the base of the filter in line with the top of the pump?
    May 2009
    Youngsville NC
    395
    You can save some bucks upfront with the High effiecncy single speed, or you can save alot more bucks over the life of the pump / pool by going the 2 speed route. Yes, you'll need to also spend the money for more advanced automation (to turn it on/off and change speeds), but over the long run you will save money (wish I would have known and realized it before I did my own pump replacement this summer).
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    Aug 2011
    Central Florida
    87
    Just ordered the WFE-3 and got a great deal. Now I need to plan what changes if any to make to the equipment layout. I'm interested in any suggestions including more info on raising the cartridge filter height. I learned a ton since finding this site.
