Thread: Stabilizer
    Stabilizer
    I added stabilizer this evening using a sock in front of the return. I did not notice that the sock on a hole in it and now some of the stabilizer is sitting on the bottom of the pool. Should I be worried about this? I did try to move it around but could not reach all areas.
    Carlotta (aka Clodda)
    Oval AGP 18x33x54 18,000 gal.
    2hp Hayward Pump
    Sand filter
    BBB Method
    Jug Dumper
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Stabilizer
    Not a problem, just vacuum into filter, but then don't backwash for a week or so, or brush it or swim and stir it up every so often.
