Thread: In the Swim Ultimate Closing Kit
    bibeaud's Avatar
    Aug 2011
    P'Burg NJ
    73
    I have a 11,000 gallon Fiberglas pool. I had planned on purchasing this (In the Swim Ultimate Closing Kit) plus a polyquat 60 algaecide and putting in the closing chemicals myself and hiring someone to walk me through the physical closing. I can put the safety cover on the pool myself with my son.
    Is this a good idea? I like the chlorine-free chemical floater. Am I going in the wrong direction?
    11,000 Gal Trilogy "Utopia" Fiberglass Pool, 1HP Jandy Pump, Jandy CS200 Cartridge Filter, Raypak 199k BTU Heater, Liquidator, CMP Off-Line Chlorinator. Cleaners: Polaris 360, Blue Diamond, Poolvernuegen Pressure
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: In the Swim Ultimate Closing Kit
    Hello bibeaud,
    Please read: http://www.troublefreepool.com/pool-...in_ground_pool also: http://www.troublefreepool.com/pool-...20group%20pool has some good pointers that apply.
    I would not waste your money on that kit, there is nothing you should need in it. Some of us use the polyquat 60 though (I have not). I believe the "non chlorine shock" in that kit is a MPS, from pool school:
    Potassium Monopersulfate:
    A non chlorine oxidizer or 'shock'. It is acidic and will cause lower pH and TA. It adds sulfates to the water. Will not break down CC but helps prevent it from forming when used on a regular basis. It will interfere with TC and CC tests unless special reagents are used in testing since it WILL test as CC! A good choice to use in indoor pools that are not exposed to sunlight but really has no advantage in an outdoor pool. It is only an oxidizer and NOT a sanitizer and should not be used as such.
    Quote Originally Posted by bibeaud
    May I ask why? Please continue to read pool school. If you want a rather detailed synopsis of this issue, see this post: http://www.troublefreepool.com/alter...uth-t3025.html
