Thread: Caulking around edge of pool
    Oct 2010
    Oregon
    18
    I have an inground plaster pool, 15x27. Along the edge, all the way around, is bull-nose brick. There is caulking between the brick & the concrete.
    Along the east edge of the pool,the caulking is pulling away leaving a gap that varies between a sliver & 1/4".
    The west side is completely intact.
    The south end is pulling away, but not as bad.
    The north end is only got a few little spots.
    The east side of the pool is on a hill with 6-7' of earth & then a retaining wall. The gap does not seem to be getting bigger, but I have not made notations about its size. I don't know if this is a gravity thing.
    Do I need to do something about it?
    If so, does the old caulk need to come out before new caulk goes in?
    Thanks!
    Bethalito
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Caulking around edge of pool
    Can you post a pic?
    You're done SLAMing when:
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    The caulk needs to be replaced if water is getting under your deck. You have to take it all out and clean the deck/brick. There are many different types of self-leveling caulks. I used the Vulcum brand that seemed to work very well. Without caulking, you risk heaving when the temperatures go below freezing. I experienced that last year where much of my deck was 1/2" higher in many places and 1" higher in a few spots. That was due to bad caulking by my PB initially with many areas exposed to water.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Oct 2010
    Oregon
    18
    Attached a couple photos.
    So...I have to pull the old caulk out & replace with Vulcum, ay? This does not sound like a fun job.
    Any tips on removing the old caulk?
    I would assume I have to go all the way around.
    Thanks!
    Beth
    That is called "Mastic" or "Dec O Seal" It is a 2 part epozy. Use silica sand to fill the voids up to about 1/4" then top...
    F
