Thread: Aqua big only cleans one side of pool
    Jun 2008
    MOBILE, AL
    65
    My aqua bug only cleans one side of the pool, I think it is due to my water circulation being to fast. Any one else experience this the the bug or the whale?
    24' AG, 52" wall ,resin with 1Hp pentair pump with sand dollar sand filter. Hayward aquatrol salt generator
    22,550
    Re: Aqua big only cleans one side of pool
    That's very possible. Have you tried pointing the eyeball to the surface and straight out, or a little reveresed, while the cleaner is in the pool? That usually helps.
    Jul 2011
    Nova Scotia, Canada
    7
    Does it still turn in both directions or does it just go on one direction? Could be something in the gears if its not doing its usual left and right movements. As for the return jet, make sure its pointed down.
    21' Sharkline Venture AGP (10,400g)
    Hayward PowerFlo Matrix 1hp pump
    Hayward 21" sand filter (200lbs)
    Hayward 900 auto vacuum
    Fafco Solar Bear 4x20
    Hard plumbed
    22,550
    It certainly could be something clogging it up. Have you taken it apart and cleaned it good?
