Thread: advice about shocking or not
    today's numbers: (TF-100)
    FC 5.0
    cc .5
    TC 5.5
    pH 7.6
    TA 100
    CH 300
    CYA 60
    salt 3400 (ideal for my swg)
    water very clear
    my question: I have had a .5 cc every day for about 2-3 weeks. The only time it is 0 is when the FC is 6-7. This has been a consistent pattern for the last month.
    I planned on doing a OCLT tonight and then shocking if I fail it. Is that a good plan?
    If I do, once I finish shocking, should I just keep the FC closer to 6 -7?
    Also, is it a good idea to boost up the CYA to 70? We will be keeping the pool open abt 1 more month, wasn't sure how important the 10 ppm of CYA would be.
    thanks!
    30000 gallon inground gunite pool
    Intelliflo ic-60 SWG, pentair tagelus sand filter, 1.5 hp whisperflo pump, tf 100 test kit,
    2 kids(tl), 1 mini-dachshund/lab mix(t),
    Central Illinois
    30,432
    Re: advice about shocking or not
    .5 cc is treated just like zero......there's nothing further to do.
    The CYA test is pretty hard to get really accurate. You could calculate a dosage of 10ppm if you already had some on hand but I wouldn't think it was important enough to go buy a new 4 lb. box.
    I was hoping I could just not worry about the cya. Good to know that the .5 cc is not a big deal
    Central Illinois
