Results 1 to 7 of 7
Thread: Slowly automating my home & pool over time
    Jun 2011
    St. Louis, MO
    3
    I am a first time pool owner, who is slowly automating my home over time. The desire to automate the new pool is a no-brainer, but I'm looking for someone to offer some guidance or advice.
    My HAL 2000 automation system is UPB based, and I don't have a need to control the pool remotely (phone, browser etc.). The low voltage lighting is not an issue, but how can I tie into my Pentair VF3050 pump? Is it only possible through using an expensive Pentair product? I also have (3) 2-way valves and (1) 3-way valve controlling flow to different features; can these be controlled (slightly tweaked) through actuators, or are the actuators simply open or closed? Same question would apply for natural gas features.
    Any thoughts?
    - 22,000 gals.
    - Cartridge filter
    - IG Shotcrete/plaster/Quartzscape
    - Pentair VF3050 pump
    - Pentair SWG
    - (2) Fire-on-Water bowls
    - (1) 5' Sheer Descent waterfall
    - (2) FiberStars Large Laminar Fountains
    22,553
    Re: Slowly automating my home & pool over time
    There are ways of automating the valves but I'm not sure about the pump. I don't have time to research it right now but I'll look into it soon. You should be able to do something.
    Support the site
    May 2011
    Orange County, CA
    696
    HAL2000 uses the X-10 powerline protocol to communicate with various devices connected up through standard household wiring. Getting it to control a Pentair 3050 pump would indeed require the IntelliComm module (you would need to get 2-4 powerline to low-voltage relays to interface X-10 to the Intellicomm, btw). My only concern would be reliability, as X-10 is not the most robust HA protocol out there. I've had better luck with Insteon devices. Alternatives are to completely automate your pool equipment using X-10 or to get a dedicated controller (e.g. like the Intellitouch) and obtain a bridge that allows you to control some functions from your HA system. I think the latter may be easier, more reliable, but also much more expensive.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    I know that Control 4, Crestron and AMX are pretty versatile home automation systems, but they require a lot of custom setup and programming. If money is not the primary concern, then one of those systems might be worth considering.
    Support the site
    Aug 2010
    Austin, TX
    200
    There is a thread on the subject of talking to/controlling an Intelliflow at cocoontech
    http://www.cocoontech.com/forums/ind...telliflow&st=0
    So you have two options:
    1) Interface with RS485 and talk via it's native protocol
    2) Use relays to trigger on/off and preset speeds via a pentair adapter
    If you are savvy with control systems, it should be no problem for you to get it to work.
    For me it was easiest to get a Jandy RS12 to control the pump and various systems/valve and then interface with Homeseer to bridge to my home automation stuff. What is really sweet for me right now is that I can see power usage on the pool sub panel, water usage, and pool/ambient temps all in the same weekly/monthly report. I'm working on getting chemical usage in there too.
    38K Gallons IG, Intelliflow VS-SVRS, 30GPM 24/7, 72sqft DE Filter, Spectralight UV, Jandy C1900 driving Liquid Chlorine and Acid (toys, I know..), Jandy LXi gas heater, Aquacal SQ175 Heatpump, Riverflow Competition swimmer, Jandy automation, Touch and iAqualink, Pebblesheen | The Build
    If you want to use the IntelliTouch for pool automation, then you could use Pentair's i-Link Home Automation Adapter Interface for IntelliTouch to integrate the pool system into the rest of the home automation system.
    https://www.pentairpartners.com/product ... ion_US.pdf
    Support the site
