Thread: Filter sand color??
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Filter sand color??
    I just acquired a used pool for disassembling and removing it. The pool had been winterized since last fall, with the filter and pump drained. It has a Hayward SwimPro 250# sandfilter, I shop vac'd about 3/4 of the sand out and brought with me. However I'm not sure it's sand, it's light grey in color, very even in texture, and finer then the sand I put in my filter. I was thinking it might be Zeo sand, but the only colors I've found for that is green and tan. The sand was crusted near the surface and sides but was loose down to the laterals where it was damp and a little clumped. It appeared to be fairly clean. Anyone know what I've got and opinions on it's re-useability. If it's just sand I'd think it is reusable, if it's something else not sure if I need or want to. We won't be setting the pool up until next spring so there's no hurry.
    Thanks
    Here's the pictures of the sand
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Re: Filter sand color??
    Use new sand.
    Support the site
