Thread: Pats for Pool built in 1965
    I have a inground pool built in 1965. Im looking for the return jets (inlets), but I have yet to find any. Any thoughts as to where I can purchase.
    Thanks
    28' AG Doughboy
    Bought Used, Installed Aug '06
    BBB
    South Central NJ
    3,192
    Re: Pats for Pool built in 1965
    Didn't see this till just now. What size are the inlet ports? Are they smooth or threaded?
    Scott
    Owner of - PoolGuyNJ LLC
    Jul 2011
    Palm Beach Gardens, FL
    22
    Hi there-
    I have a similar problem and wanted to jump in here. I have to replace my inlets as well from a pool built in '64. I have had a hard time finding any return jets for them and at least 1 local pool guy said that he "had never seen anything like them before". After adding a pressure-side cleaner to one of the returns with a good deal of modification to the connectors, I now would like to find the correct fittings and connectors if possible. I even had a custom adapter machined in order to connect the 'normal' 1-1/2" threaded pool cleaner to the return jet!
    Here's what I do know about the inlets:
    1) The return lines are smooth, not threaded.
    2) The nozzle is held in place with a faceplate that is attached with 3 (or 4?) screws.
    When I get home, I will take a few measurements, and snap a couple of photos to see if that helps jogs someone's memory.
    Thanks-
    -stephen
    23KG 16x32 gunite, 120 sqft cartridge filter, 768 sqft solar panels, CircuPool RJ45 SWG
