Thread: help. irene left wrinkles
    lindaspoolboy's Avatar
    north NJ
    23
    due to water pushing up at the liner from irene, the liner was pushed out.
    once the water drained away, the major bubbles we pulled out (!)
    but at the low end of the pool i've been left with wrinkles.
    is there anything i can do to remove these wrinkles ?
    pic attached with sample wrinkle.
    thanks
    lindaspoolboy
    29,000 gallon vinyl IG, Hayward 1.5hp Pump, DE Filter.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: help. irene left wrinkles
    Here's one member's solution to 'big wrinkles' from a while back: a-solution-for-big-wrinkles-t6907.html
    You're done SLAMing when:
    north NJ
    23
    i'm afraid i dont have the courage to try that solution.
    thanks for the reply.
    - lindaspoolboy
