Thread: I need to drain hot tub into pool....
    partypond's Avatar
    Jul 2008
    Frisco, Texas
    89
    The hot tub fountain broke and a piece is still partly in the hole in the hole in the bottom of the hot tub. I can not get it out so draining the hot tub into the pool is my next option. I have the Aqualink pool remote so the valves are on remote changers so I can't just close the hot tub return (I think). So this is my question.,.. How do I get the suction of the spa to work and not the returns so the water will just go to the pool until I am done. If you need more set up info please let me know OR if you have other ideas, I am open to options.
    I have posted pic of controls....
    36x16 gunite, 14,500 gallons, Jandy 2.0hp VS Epump, Jandy CL460 filter, Automatic chlorinator, Jandy Legacy 400K BTU Heater, Polaris 1.5HP spa blower, 2 Colorlogic pools lights and 1 Colorlogic spa light, Polaris 3/4HP booster pump, Polaris 280 cleaner, Jandy PS4 with PDA, QuartzScapes Montego Bay plaster, OK flagstone coping, spray deck (aggregate effect) - completed 3/2011
    Optica's Avatar
    Jul 2011
    Southern California
    70
    Re: I need to drain hot tub into pool....
    Most automated control systems have a manual mode or service mode that allows you to move individual valves..can you access this mode and change the suction to the spa but keep returns on for the pool. This will drain the spa like you want.
    What is happening in your picture. Looks like water spraying out of your filter, or is it rain or something?
    ___________________________________________________
    12,000 Gal IGP, Gunite/Plaster, Pentair DE & Pump, Heliocol Solar, K-2006, BBB'd & Borated.
    partypond's Avatar
    Jul 2008
    Frisco, Texas
    89
    Thanks for the info. I can put it in service mode and see if that works.
    The pool is under construction in the picture (completed 3/11) and they were running water thru the filter to clean out all the pipes and test some lines.
    Apr 2011
    Seattle
    31
    I don't think you can do it from the remote, but the "PS4 power center" (looks like a large breaker box) has a control panel inside with a "spa drain" mode that will pump the water into your pool.
    Here is a link to the install manual which has some pics: http://www.jandypoolproducts.com/pdf/aq ... manual.pdf
    20k gallon free form plaster pool with a spill over spa, sand filter, Master Pools in floor cleaner, Jandy PDA and Jandy Lite2 natural gas heater.
    Jun 2010
    Dripping Springs, TX
    125
    If you are talking about automated valves, there is a switch underneath them that allow you to manually control the position of the valve.
    Feel around on the bottom of that valve and you'll find it.
    Two things - make sure the pumps are off when you change the valve, and also make sure to put the valve back to it's original position when you are done so that the automation system works properly.
    17K gallon IG freeform Pebble-Tec pool w/ raised spa/waterfall, Hayward 6020 DE filter, Tristar 1 HP circulation pump, Tristar 2.5 HP spa pump, Silencer 2hp blower, Aquarite SWG, Polaris 280 w/ booster pump, Hayward Universal H-Series 400K LPG heater, Ultrapure Ozonator 25, Aqualogic PS-8
    partypond's Avatar
    Jul 2008
    Frisco, Texas
    89
    THANKS for all the info! I checked the control panel and there is a "drain spa" setting so I will try that today. I also found the switch at the bottom of the valves so that is good to know also. Hopefully this will work and I can get my fountain working again.
