Thread: Possible bad R-0003 reagent?
    I recently broke out a new vial of this reagent. Now I'm suspecting that it is possibly bad because my CC numbers have been uncharacteristically low (more or less zero when usually I run about 0.5-1 due to so many leaves that fall into my pool).
    Is it possible that this reagent is bad, or am I just running my pool just right for once?
    Thanks!
    - jeff
    15,000 gal SWG pool, cartridge filter, all pentair equipment, variable speed pump, 400K BTU heater and spa, pebbletec finished
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Possible bad R-0003 reagent?
    What color is it?
    R-0003 is DPD Reagent #3. It should be a clear colorless liquid. If it turns yellow, it has gone bad.
    It is clear as water, colorless.
    Montreal Canada
    326
    What's the lot number? It's on the bottle, format looks like 1081A.
    Lot 2071A
    Montreal Canada
    326
    Should still be usable.
