Thread: Pool Deck
    Apr 2011
    Cleveland, TN
    14
    Pool Deck
    Looking for advice on how to best seal my concrete deck without it becoming slippery. Leaves and mud stains it easily. It was installed this spring. Thanks
    18x36 Vinyl Pool. Superpump2 2 speed motor. Sand Filter.
    Apr 2011
    Cleveland, TN
    14
    Re: Pool Deck
    Help!
    Re: Pool Deck
    Well the most important part is prep. what kind of finish is it?
    F
    Apr 2011
    Cleveland, TN
    14
    Re: Pool Deck
    Its a plain brushed concrete surface
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    Re: Pool Deck
    DecK-O-Seal makes products that might work for you.
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    Re: Pool Deck
    I still have this to do as well. I will tackle this next year. The prep will be the most time consuming. I was going to use this product. http://www.hcconcrete.com/products/soli ... ed-sealer/ with an additive they call shark grip for slippage. It is a product you can get at a shermin williams paint store or Lowes. The neighbor used the H&C concrete stainer and then applied the clear coat. Looks really good.
    21,500 Gunite Free Form ~ 18'X40', Sun Deck w/ foam jets auto valve, 3-Laminar Deck Jets w/ auto Valve, 1-Swim out, 3' to 8' deep, NPT Raku Tile
    All Sched 80 Pipe, Pentair Easy Touch control, Pentair pump and Sand Filter, Raypack Heater, White Plaster, Saline Chlorine Generation, Letro Platinum cleaner w/ booster
