Results 1 to 14 of 14
Thread: High CH
    High CH
    is the only way to lower my CH is drain the water?? I've been fighting high CH all summer and currently sit at 500.
    My tap water has a CH of 150.
    14,000 gallon IG plaster pool, Cartridge Filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: High CH
    Quote Originally Posted by thabeezer
    That and reverse osmosis treatment. Are you using cal-hypo to chlorinate?
    Re: High CH
    Quote Originally Posted by linen
    I use bleach
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: High CH
    Over time evaporation followed by topping off can cause it to creep up too.
    Re: High CH
    That may be my cause since it's been so hot and dry in Texas
    30,426
    Re: High CH
    You can do multiple drain and refills to bring it down. 500 is high but certainly not unmanageable...what issues are you having?
    Re: High CH
    Starting to get calcium scale on the tile grout. I even had some scale on the joint of the coping outside the pool
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: High CH
    Could you list a full set of your most recent test numbers? Especially ph, TA, CH, CYA, salt levels, borate levels, temperature...your CSI (Calcite Saturation Index) might indicate your issue. It can be calculated on the poolcalculator.com
    Re: High CH
    FC 9
    ph 7.2
    TA 90
    CH 500
    CYA 90
    borates 50
    Water temp 90
    Csi -.14
    Water clear
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: High CH
    Assuming you have no salt (you would have to have a lot though to put you in danger), that is the csi I get too. hmmm....
    30,426
    Re: High CH
    Scaling would not appear with those current numbers. If it IS scaling, I imagine your pH and TA have been much higher in times past.
    You may be experiencing efflorescence rather than scaling. That's the migration of minerals from beneath the grout and is unrelated to your pool water. I don't know it's cause but muriatic acid in a 3:1 mix will clean it off. It can also be removed mechanically. I have it on about 3 feet of my scum line tile....nowhere else.
    Re: High CH
    I've had the pool about 3 months (new house) and have been using BBB the whole time and ph and TA have been in check.
    I'll try the MA solution to clean it
    30,426
    Re: High CH
    Yeah, since you know your pH history and it is forming on the grout, I would suspect efflorescence. It'll probably keep coming back for a while but will eventually stop.
    Re: High CH
    So having some free time to research efflorescence it looks like that is the culprit..I am going to mix up some water and MA tonight and see if that takes care of the problem.
