Thread: Return Plugged
    Jun 2011
    San Diego California
    88
    Return Plugged
    I'm still relativley new to the pool world and have an older inground pool that's had a return plugged since we purchased the house a few months back.
    I purchased a drain king to try and push whatever is in there back to see if I could clear it. Well, when the hose was turned on, I heard a pop over by the pump/pipes. When I checked, water was everywhere and there is a stand alone pipe that comes out of the slab that had the cap blown off. The pipe is not conencted to anything, just straight out of the slab, normally with a cap.
    During this process, the drain king slipped out and exploded. I shut the water off, and put the cap back on the pipe. When I checked the water flow of the return, still nothing. I plan to get anotehr drain king and start again.
    However, can anyone tell me how this stand along pipe with a cap works into the pumping? Why woudl pushing back cause it to pop? Ther eis another stand alone pipe next to it, but it has a U on top point down, but with no cap on it. Like a pressure release or something.
    IG, 13,000 gal, concrete, DE, VS Intelliflo Pump, Intellichlor SWG
    San Diego, Ca.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Return Plugged
    I expect it is an unused cleaner port.
    Jun 2011
    88
    Re: Return Plugged
    I think you got it. I re-tested it and water flows both ways with no issue, to its a line with nothing connected. Its a 1" line, with another un-used 1" line next to it (on the slab).
    Any ideas what the other unused one woudl be for? There are no other returns/cleaner ports in the pool.
    San Diego, Ca.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Return Plugged
    If it's not for a proposed cleaner line, it might just be a 'reserve' line - one that can be plumbed in if a suction or return line breaks.
    When you winterize, if you winterize, be sure to blow that line out and plug it!
    Luv& Luk
    -Ted
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Re: Return Plugged
    Does you pool have a spa built in? If so the open line could be an air feed to the spa.
    chiefwej
