Results 1 to 10 of 10
Thread: SWG?
    Louisiana
    127
    SWG?
    Well after 5 years or so my Aquarite is out of commission. Noticed this morning that the board has some burn spots on it near the big black capacitor or whatever you call it. I did change this out last year but looks like it burned out again plus also the board around it. I figured between changing the board and the cell, which is probably going to go out next, that i should just purchase another. What is new out there that you all would recommend using? I had that Aquarite for 40,000 gallons.
    27' Radiant Metric, 17,100 gallons
    Pentair Dynamo 1.5hp 220v
    Circupool RJ45, Sand Filter, Borates
    Dolphin DX6 Robotic cleaner
    TF 100 Kit
    Re: SWG?
    AquaRite is still one of the top units out there. If you want to save some money, take a look at CompuPool.
    Aug 2011
    Oglethorpe, GA
    15
    Re: SWG?
    I just did some research and found CircuPool. For the money, it looks like the best system out there. I'm certainly no expert, and a newbie to SWG, but I think I got a good buy on a quality product. Here's where I got mine...this is a good comparison chart. Might be biased, but from what I can tell all the data is there:
    http://www.discountsaltpool.com/Full_Ma ... arison.htm
    In-ground vinyl 16x32, 17,500 gallons
    Sand filter, CircuPool RJ30 chlorine generator
    Louisiana
    127
    Re: SWG?
    How good and reliable is the Circupool brand? 7 year warranty is a good thing and will the box stand outdoor heat and so on without being covered since it looks like it has a plastic lid.
    TF 100 Kit
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: SWG?
    I've got a Compupool CPSC48 on a 17K pool. It runs for about 7 hrs at 60% and has been great.
    Re: SWG?
    I just bought a CircuPool RJ45 and had it for two weeks which means not much at this point. I can only tell you my thinking process. I narrowed down my selection to the Compupool SC48, CircuPool RJ45 and Aquarite40.
    - CircuPool and CompuPool are made by same manafacturer. Reviews are good on the CompuPool and not many review on the Circu (probably due to not many owners). So I am banking that the RJ45 will work as good as the SC48. The dealer did tell me the controller on the RJ series is updated an newer than the SC48 and should last longer hence the 7 yr prorated warranty.
    - I have a 21,000 gal pool so I need a larger unit which brings the prices on the SC48 and the RJ closer. When I bought my SWG you get the next size up for same price as lower model.
    - Aquarite was more expensive at around $880 compared to $799 for other two.
    - Output on RJ45 was around 2lbs of CL and that seems about right based on calculations in last paragraph below.
    - It boiled down to warranty eventhough it is prorated after the 5th year you still save 20% off parts so worst case scenario a new RJ 45 is 899 so it will cost $720 to replace both parts. Right now after 5 years, both your cell and controller are about done so it is costing you either $880 for a new Aquarite or $799 for a SC or RJ. Actually worst case scenario is that if both my controller and cell break after 7yrs and I will have to buy a new unit.
    I have .5gal (10.5%) Chlorine demand and the CircuPool is running at 50% for 12 hours and my pool has 3-4ppm of CL at all times. I do have an issue with the unit reading salt higher than what is expected but I will look into that later this week. I estimate my salt level to be 3350 vs 5700 & 6000 what the controller reads. Estimate based on having salt at 2100ppm before SWG and adding 220lbs of salt.
    Hope this helps.
    20x40 24,000 gal IG plaster/CircuPool RJ45 SWG/2 skimmer/2sp 2.5hp Jandy Stealth/340sq ft cart filter/600sqftHeliocol Solar Panels/6ft semi circlr tanning ledge/25ft deep end bench/5ft sheer descent/2 lion head water features/1300sqft travertine paver/2 Colorlogic lights/Hayward Navigator/3step 2ft raised bond beam
    Louisiana
    127
    Re: SWG?
    Thanks all again for the replies. I have 18,000 gallons and i am currently using a Aquarite 40. I just fixed it yesterday and got it back running, but then i know it will be a matter of time before having to replace. Right now the Circupool as a pretty good deal which if i buy the RJ30 for $799 i will actually get a RJ45, from what i am reading on site. I am just unsure how well the controller is built since it looks plastic and this will be outdoors and uncovered and i do not have any shade where it will be at.
    TF 100 Kit
    Aug 2011
    Oglethorpe, GA
    15
    Re: SWG?
    Circupool's warranty, coupled with the price is what sold me. I goy the upgrade deal too. Can't beat it.
    Give them a call and ask what they recommend as far as shelter. I called with a question and they were very helpful.
    Louisiana
    127
    Re: SWG?
    Think i may pull the trigger on the RJ30, which they should give me the RJ45. Thanks all for your help.
    TF 100 Kit
    Aug 2011
    Oglethorpe, GA
    15
    Re: SWG?
    Go for it.
