Thread: only 7-8 weeks on pool light gasket - can I reuse?
    Mar 2008
    Lake Forest, CA
    114
    Long story short...I replaced my pool light bulb and gasket about 2 months ago, and it looks like I'm going to need to replace the bulb again. After such a short period of time, can I keep the same gasket (provided it looks OK upon inspection)?
    Greg
    12000 gal IG pool/spa combo,60 sq ft Jandy DEL filter,2 hp Jandy Stealth pump,Jandy LX400 400K BTU gas heater,Pentair Rainbow 300 off-line feeder (never gets used),Jandy Aqualink RS4 with PDA remote,3 Jandy 12" sheer descent waterfall features, Dolphin Oasis Z5 robotic cleaner
    South Central NJ
    3,192
    Re: only 7-8 weeks on pool light gasket - can I reuse?
    I would NOT. I would replace it.
    Scott
    Owner of - PoolGuyNJ LLC
    Mar 2007
    Coastalish 'down easter'
    4,160
    While I hold Scott in great esteem, I humbly disagree on this one
    You can try the old gasket and then submerge the light for a minute and see if any water enters it. I've replaced bulbs in units that were over 7 years old and not had a problem with the gasket
    Luv& Luk
    -Ted
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    I too have re-used a gasket. About a thirty day old one, and its still holding. Easy way to tell if your gasket is no longer of use, is to hold the fixture under water and have someone(owner) turn it on and watch as the fixture warms up, the pressure will force it's way out anywhere the seal is weak. This is also good for checking questionable light cord grommets on the fixture. Course once the light cools, seal leaks again only this time its sucking water back into the fixture.
    Ted, I've never seen water actually enter the fixture This must be what you meant. Pardon if i doubled.
    Factory Warranty Station for:
