Thread: Help with valve
    Help with valve
    I recently moved into a house with Salt water pool. I need help with one of the valve, which I think is the water coming to the pump from pool. It is set to close. I was wondering if there is any reason for the valve to be close. Could it be something else rather thn the water coming to pump from pool (Picture included).
    I have 2 skimmers, multiple returns to the pool. 1 Drain at the bottom.
    Its the valve on the right on the picture.
    Thank You
    Apr 2011
    Lynchburg VA
    393
    Re: Help with valve
    I hard to tell where some of the plumbing lines are going to, can you take a picture from a side angle?
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Re: Help with valve
    here are 2 more pics, if they help. I can take some more if needed.
    Thank You
    30,413
    Re: Help with valve
    It is water coming from the pool to the pump but from three different sources. Probably a main drain and two skimmers but you'll have to experiment with the settings to see which combination gives you what result.
    Label the settings when you get it resolved.
    Re: Help with valve
    is it not best to open all three? I opened the 3rd one for less then a minute and there was lot debris (mainly leaves) that came in the basket. So I closed it again.
    At the present setting, both skimmers seem to be working.
    Feb 2011
    Petaluma, Ca
    665
    Re: Help with valve
    It prob regulates the flow between the drain and the skimmers, maybee the valve you opened was from the main that had collected debris. I think as a general rule it's good to have water pulled from both the skimmer and main drain, thats how mine was set from the beginning, if i want more skimmer action I can close the main drain and all the water will go through the skimmer, or visa versa.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
