Thread: Lube For Threaded PVC into Pump?
    What should I put in the threaded PVC I need to screw into my pump? Can I screw it in without anything? Use Teflon tape?
    BigT8600's Avatar
    Aug 2011
    Shreveport, LA
    53
    Re: Lube For Threaded PVC into Pump?
    Teflon tape would be your best bet. Thats how my pool builder originally put mine together and when I hard plumbed mine i used tape. Works well to help seal but also let you take it apart again if needed.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Teflon tape will work, but I find it easier to use pipe dope designed for plastic fittings, especially on the larger fittings like the pump connections.
    BigT8600's Avatar
    Aug 2011
    Shreveport, LA
    53
    Quote Originally Posted by JohnT
    I have a tiny drip coming from the bottom of my skimmer basket to my hose. Would pipe dope help seal this better than teflon? Never thought about using it.
    My plumber, who is an absolute perfectionist swears you should use Teflon tape and pipe dope. He says the dope not only helps seal but lubricate during assembly so less of the teflon is taken away by friction. That's what I do know and have never had a problem.
    I never thought I would live long enough to see a plumber so particular about his work.
    10,800 gallons Gunite/Plaster
    Hayward 244t 24" Sand Filter with Zeo
    1 1/2 HP Challenger
    Digital Pool Pilot DIG-220 SC-48
    Located in NOLA
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Quote Originally Posted by Dalandlord
    That's the way I've always put threaded PVC together. First about two wraps of teflon tape followed by pipe dope. I use Rectorseal No. 5 for the dope. When you do it that way the fittings can be put together hand tight and you don't need to screw them all the way in. They also come apart easy.
    A trick I learned from a pipe fitter years ago to stop leaking joints caused by threads that are buggered up is to first put a thin coating of pipe dope on the male threads then wrap them with sewing thread or thin (2 lb) nylon fishing line followed by a top coating of dope. Just make sure the line stays in the valleys of the threads and does not cross over the the top. This works particularly well for threaded stainless steel fittings that are notorious for being hard to seal.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
