Thread: Pump Question
    mvk111's Avatar
    May 2011
    Tampa, FLorida
    62
    Pump Question
    So the builder installed a 1hp 2 speed Sta-rite super pump instead of the 1 1/2 hp that was in the plans and I wanted.. This obviously upset me when I caught it today. I called and they said well he installed it because he felt the 1hp was enough for your pool and it would save you money. So my question is should I have them replace the 1hp to the 1 1/2 hp or should I keep it. The principle of the matter makes me want to change it to what I ordered. Is the 1 1/2 to much for my pool and system. I have a waterfall, bubbler and a 53' Sta Rite DE Filter for approx. 11000 gallons or a little bigger better.
    Your opinions are wanted...let me know...thanks.
    15x30 free form (10,500 gal) SWG
    Gunite, Game depth 3.5-5-4 ft, 1 hp Sta-Rite Super Max 2 speed pump, 53' Sta-Rite system 3 DE filter
    Pentair Intellibrite LED
    Pentair 125k BTU ultra temp heat pump,
    Screen Enclosure
    TF-100 Test Kit
    Re: Pump Question
    In most cases a smaller pump is better. You only want the larger pump if you have a spa or waterfall or other water feature that requires the extra HP. For normal water circulation you want the smallest pump that will work in order to save money on electricity. Larger pumps use more electricity to move the same amount of water compared to a smaller pump.
    mvk111's Avatar
    May 2011
    Tampa, FLorida
    62
    Re: Pump Question
    So since I have a waterfall (2' sheer descent) and a bubbler should I go with the 1 1/2 like I planned?
    Screen Enclosure
    TF-100 Test Kit
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pump Question
    I agree with Jason, I have about the same size pool as you (though mine is an agp). I have a 1 hp 2 speed and only use the high speed when I am circulating through my solar panels 16 feet above the pump. For everything else the full speed is overkill. I think the pb is actually being smart, though he probably should have discussed it with you first.
    22,537
    Re: Pump Question
    What I would suggest is to try the pump running the waterfall and see if it supplies enough water. If it does then you'll be better off staying with the 1 hp. I'd have it understood that if the waterfall didn't have enough flow he'd be responsible for replacing the pump. Also don't be fooled by hp. Some 1 hp pumps have a higher flow then some 1½ hp pumps so don't get stuck by the numbers.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    mvk111's Avatar
    May 2011
    Tampa, FLorida
    62
    Re: Pump Question
    Thanks Bama.....everything flowed exceptionally well......keeping the 1hp !!!!
    Screen Enclosure
    TF-100 Test Kit
