Results 1 to 11 of 11
Thread: Hurricane Irene....and my pool.
    May 2011
    New Jersey
    37
    So, I just spent the last month getting my pool to the "sparkly" level and maintaining fabulously. Went through the shock process and all and here comes a hurricane to
    ruin it all. Seriously though, here's my thoughts. I am in coastal NJ. Inland enough that we won't have to evacuate but in the direct path either way. We are going to lose power. For how long is anybody's guess. Can I, at least, delay the eventual "swampitis" if I bring it to shock level or above. I also plan to put the safety cover on to prevent debris from entering the water. Of course it's hot here and the water temp is in the upper 80's. I am just trying to delay it for, say, maybe a week?
    thanks guys.
    Kristyn
    8100 Gal 12X20 vinyl IG pool. Hayward H200 heater, super pump and Pro Grid DE3620 Filter.TF100 test kit
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Re: Hurricane Irene....and my pool.
    Hi Kristyn~
    Regarding the cover, DH and I had an alternative thought: we are leaving our newish Loop Loc cover off because we would rather have a mess in the pool than to have a branch come off one of our many trees and stab a hole in the cover. Do you have anything near your pool that could trash your cover?
    Others will be along to advise about the chlorine. We've stepped ours up to Boost in anticipation of power loss. We also have jugs of chlorine standing by.
    Good luck!
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
    Feb 2008
    Denton, TX
    5,061
    I would consider how much chlorine you go through per day, and then I would add enough chlorine to maintain the pool for the amount of time that you could reasonably expect the power to be off. For example, my pool loses 2.5 ppm of FC per day. If I expected the power to be off for say, 5 days, I would add 12.5 ppm of chlorine at a minimum. In fact, I would probably add a bit more because my pump won't be working and I'll be getting lots of rain. In any event, raising your baseline FC ahead of the storm can only benefit you in the long run. You may still end up with some algae but you might not have as much algae to deal with as you would if you were to do nothing.
    You might think about leaving the cover off while the wind is blowing. That cover would make a heck of a sail should it come loose.
    Then after any debris is raked out of the pool, top off the chlorine and cover it up.
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by anonapersona
    Absolutely a good idea. Anything that can blow through the air most likely will and therefore, poses a safety hazard.
    May 2011
    New Jersey
    37
    what about damage to the liner if something should get into it that's pretty big, scratchy or glass??
    Kristyn
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    I don't know if anyone here covered their pools during Ike, but I do know the wind from a hurricane can weaken fabric very quickly. On an in ground pool that is completely flat to the ground using a safety cover may work just fine to keep out debris, but on anything elevated, even a spa, the cover will either shred or fly off. It just takes a little bit of an opening for the wind to get under and create havoc. A solar cover will be gone, a tarp style winter cover will be destroyed.
    The biggest risk to a vinyl pool is debris ruining the liner. It happens even with heavy thunderstorms or snowstorms that down trees. The best thing you can do is make sure any potential "flying objects" on your property are removed or secured in a house or sturdy garage.
    Love TFP? Become a
    TFP Supporter!
    Pisces's Avatar
    Jun 2008
    League City, Texas
    273
    Good luck, Kristyn..just keep you and the family safe...do as much as you can ahead of time, but you can get the pool in order afterwards...great advice from everyone! We are 25 miles from Galveston and stayed here in the house through Hurricane Ike (interesting night but we were OK - strong house and higher ground), but it was right before we started the pool build, so unfortunately I don't have any really great input on that score, but have had the pool overflow a couple times with rainfall. You guys are in my thoughts and prayers up there.
    7,000 gal. IG gunite, SWG, PebbleSheen interior finish-Aqua Blue, 8' vanishing edge raised 16-jet overspill spa, 2 12" waterfalls, tan shelf with bubbler.
    Pentair equipment: Easy Touch 8, Intellichlor IC-40, Intelliflo VF 3050, 2.5 hp Whisperflo spa pump, 1 hp Whisperflo water feature pump, Quad 100 DE filter, Master Temp 400 heater, Legend Platinum Cleaner (3/4 hp pump). Autofill, TF-100 Test Kit w/salt and borate strips.
    Pisces Pool Build
    A reminder to all those in hurricane prone areas that are not lined up for Irene right now.... this is the time to look at trimming your trees to remove weak branches and to prune to let the big winds blow through safely.
    Just as Hurricane Rita was heading toward Houston all my neighbors were in their front yards watching my tree trimmer at work, wishing they could get him to come to look at their trees. It is too late to get those appointments once the storm is coming, I had that day booked a week earlier right after returning from post-Katrina New Orleans. We were just lucky that it got done.
    Pisces's Avatar
    Jun 2008
    League City, Texas
    273
    Yes anonaperson....very timely advice. We are in a fairly young neighborhood without big mature trees thankfully. I really don't want big trees around the house now. Glad the front two oak trees are fairly slow growing. We trim the branches some every year. But yes, it was the bigger trees falling that caused a ton of damage around our area and especially north of here.
    Pisces Pool Build
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by 257WbyMag
    From what I have been told on here that will not work. I have been told you lose a percentage of your chlorine. So at higher FC levels you may lose more than the 2.5 you lose daily. I have tried to recommend this for people going on vacations, but have been told it will not work due to losing a percentage of it per day not an amount.
    Example
    2% of 20 is more than 2% of 10.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
