Thread: max FC with vinyl pools
    At what chlorine level does a vinyl liner bleach out or start to get damaged? I've been assuming that it is OK to shock at normal shock level or somewhat above is OK, all the way up to mustard algae shock levels based on CYA..... but is this true?
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: max FC with vinyl pools
    well the max level is going to be based on how much CYA is in the water. I've seen pools damaged by relatively small amounts of chlorine because there was no CYA present.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Mustard algae shock level is fine for a couple of weeks. You wouldn't want to run your FC level that high all season however.
    OK, how long at mustard algae level is too long is good to know. I don't have a vinyl pool and so never read up on that.
    Aug 2009
    Central NJ
    47
    Thanks for asking & for the answer. I was actually searching the forum for this earlier today & then saw this question posted, so I just waited.
    Andy
    11K gal 15x30 AG; 1.5 Hp Hayward pump + XStream 150 sq ft cartridge filter; AquaCal SQ110 heat pump; solar cover; Pool Rover Jr cleaner
