Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Attn: East Coasters in Irene's path
    South Central NJ
    3,192
    Public service message:
    Do not cover your pool. It could blow away. This includes those with automatic covers. Unless your pool and it's equipment are on your homeowners, the repair is on you.
    Boost your chlorine level to 10X the proper level shortly before it hits. 6% Bleach like Clorox or Great Value is best.
    Turn off the system at the main panel's breaker to the sub-panel outside. before power goes out or you get a spike when another area goes off line, This will preserve your pumps and automation systems until power is reliable again.
    Secure patio sets. Those with gunite pools might be able to pull the cushions off and set the chairs in the pool. They won't go anywhere. Obviously, don't do this with wrought iron type furniture. :-/
    Turn tables upside down. They won't catch much wind that way.
    Secure the shed.
    Don't put things where they can fly. 100 MPH winds are no joke!
    Neither I nor TFP assume any liability for incompleteness but felt compelled to do something.
    Scott
    Owner of - PoolGuyNJ LLC
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: Attn: East Coasters in Irene's path
    Good suggestions all.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    South Central NJ
    3,192
    Bumping to keep near the top of Active Topics list.
    Scott
    Mar 2011
    Houston, Texas
    413
    After living through Hurricane Ike (a strong category 2 hurricane) a few years ago, before we built our pool, if Irene hits with 100+ mph winds you can assume widespread power outages (unless the main lines and lines to your home are all buried). Trees will fall and knock down the power lines and the damage may be so widespread it will take a long time to repair the lines.
    Stock up on clorox if you have a SWCG. We were without power for 10 days after Ike and many parts of Houston were without power for 3 weeks--and we are more accustomed to hurricanes than New England and the upper mid-Atlantic states.
    Of course, make sure you have batteries, flashlights, food, ice, full tank of gas, etc. Another good tip if you live near sea level and if you are able to do it, is to move your furniture or other valuables to higher ground. Unless you have flood insurance, your basic homeowner's insurance policy may not cover a loss from rising water--but it probably covers a loss from wind damage.
    And it should go without saying that if the hurricane is a Cat-3 or higher and it's headed right for you then you should probably evacuate to a safe place.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Wishing everyone in the path of this storm the very best. Best wishes, thoughts, and prayers for you and your families.
    Essential Links:
    chessie6's Avatar
    East Hartford, Connecticut
    187
    Thank you so much for the safety tips, thoughts, and prayers. I was going to leave the solar cover on the pool but now I will definitely take it off and secure it. My area is under a tropical storm watch but I'm not taking any chances. Will keep you posted on how things progress here; I'm definitely quite nervous.
    Jan
    Summer: 19 x 37 Pacific Graphex IG modified oval, aztec marine vinyl liner, 24,000 gal, 3.5 feet to 8 feet, 1 hp Hayward C4025 Swim Clear 4-cartridge filter, 12.5% Liquid Pool Shock for sanitizing, 1 super wide mouth skimmer, 4 returns (2 therapy jets in steps), Hayward Heat Pro heat pump, non-curved pool slide, 6' jump board, 8 ml blue solar cover, TF-100 test kit, had pink algae in 2010 Winter: Hot Springs Vista Spa, 500 gallons.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes, please do Jan, let us know how it goes. I would imagine you are riding it out? I know some folks in L.I. NY I'm wondering about. They are riding the storm.... so we will see how it goes.
    Essential Links:
    chessie6's Avatar
    187
    Yes, we are riding it out; no recommendation has come for us to evacuate. We are in East Hartford and are in the higher areas away from the river, but I'm concerned for a friend in Fairfield county. Sending wishes for your friends to be safe, too - LI is supposed to get it worse than us.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Wishing you all safety and health, and minimal damage. That's a freakishly massive storm out there about to hit a lot of people. Take care everyone.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    DaneCE's Avatar
    Jul 2011
    VA
    279
    Thanks for the tips. I had planned to dump a ton of Chlorine in but 10x, wow. I'm in SE VA so she's on her way to my house.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    That image always scared me.
    Living in Baton Rouge we had Gustav a few years ago, generated tornados etc. My parents started the storm with 21 trees on the lot. Ended with ZERO. Incredibly none landed on the house directly though there was some branch damage and an aluminum patio cover was destroyed. One tree was so close to the back of the house, the back doors couldnt be opened.
    Now everybody has a generator, box fans and even a window AC unit (or two!) tucked away for the long wait for restoration of power after one of these. For us it was several days for power.
    Aug 2011
    Virginia Beach
    295
    Just watching the raindrops making ripples in the pool here in Virginia Beach. It's gonna be a LOOOONG weekend, and not the good kind.
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
    Butterfly's Avatar
    South Carolina
    10,045
    Bump
    You're done SLAMing when:
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,053
    Quote Originally Posted by Brushpup
    Second this
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Jul 2011
    Lehigh Valley, PA
    163
    what about the pool overflowing ? I dont intend to run my pump. What should I do ? I know overflowing cant be good. My pool installer recommended I drain a few inches out of the pool. Thoughts ?
    21' All Steel AGP with Resin caps, Heyward S244T Sand Filter, Heyward 1HP 2 speed pump
    Quote Originally Posted by gdog2004
    You ought to be able to siphon water out of an AG pool with a hose run to any lower area. As long as the hose is full of air, one good draw on the end should start the water running over the rim, then gravity takes over. Depending on where the pool is and where the end of the hose is and how far from the house that is, you may be able to manage that even during the storm. The key is to fasten the end of the hose inside the pool at the depth you want the water to stop. When the suction is broken it all stops.
    Taking a few inches off the top of the pool in advance would be smart I'd think. What is the rain forecast for your area?
    I will point out, that with hurricanes, sometimes 30 miles is as good as a miss. That is, if it is 30 miles further away than forecast, all the predictions fall rapidly. A lot of areas that are forecast for 10" of rain now will not see but half of that when it is done. No telling where those areas are, however.
    Aug 2011
    Virginia Beach
    295
    My water level went from normal, up 6-8", then down 18". This is the last season for this pool, so I'm not terribly worried about it. I actually got in for 30 seconds or so earlier today after I finished some emergency outdoor drain cleaning. I got out just as dry as I was when I got in- sneakers & all. The storm hadn't ramped up yet, so I went for it. (my sparklyitis has faded as of a few days/week ago)
    Virginia Beach, VA
    Leisure bay hot tub
    Hey Coastal Carolina here, we live inland about 100 miles from the coast of NC. Winds were pretty bad, and lasted a looooong time. I was blessed to have never lost power and I took everyone's advice about bumping up chlorine before storm hit. The entire bottom of my pool was covered in leaves and debris. Spent about and hour raking leaves and vacuuming. Tested water and she's good. Just a tiny bit cloudy, but bumped up chlorine again tonight and running pump 24/7. Thanks to all for your advice. Usually our storms come in September, but Irene came early and my pool was still up. No damage and I am very thankful. Hope to hear from others that they weathered as well. Scary storm!
    18x52 Ultra Frame with 1600 gph sand filter and intex skimmer
    Feb 2011
    Sicklerville, NJ
    80
    I live about 40 miles from the coast. Thankfully, I did the sensible thing and covered the pool. It has a carpet of leaves on the cover. The wind finally stopped a few hours ago. Cover comes off tomorrow!
    25k gal Lazy-L, vinyl liner, poly walls, swimout spa, diving board, TurboTwister slide.
    Hayward 2HP 2-spd pump, Pentair 2HP spa pump, Hayward 30" 500lb sand filter.
    Goldline Pro Logic PS-8 automation/SWG. 2 LED ColorLogic 4.0. 8 Jandy deck jets. MX-8 cleaner.
  20. Back To Top    #20
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Just wondering how everyone did.
    Essential Links:
