Thread: Uneven ladder help!
    Uneven ladder help!
    OK so I'm new here and just had a pool installed today....problem is, pool came with an A-Frame Roll Guard Ladder BUT in order to level the pool it had to be dug down 19 inches in the area closet to house where we had them leave a section of fencing off so we went to put the ladder in and DUH it doesn't work now b/c the yard is 19" higher outside than the bottom of the pool...I'm trying to avoid digging down around the ladder causing people to step down to go up the ladder. SO my question is does anyone make a ladder that is shorter on the outside or adjustable? Not sure if this makes sense, I really don't want to put the ladder on the other side of the pool where it would be most level b/c it is basically the back of pool from the house so you would have to walk around the pool to get in.
    ANY help would be great. Thanks!
    BigT8600's Avatar
    Aug 2011
    Shreveport, LA
    53
    Re: Uneven ladder help!
    can you add extensions to the side that goes in the pool? hmm....i had a similar problem but had to dig down my outside to level it out. can you post a pic to show us what your ladder looks like and where you want to put it?
