Results 1 to 8 of 8
Thread: no chlorine = too much chlorine
    Anyone can explain to me why since nearly 1 month now, I haven't add any chlorine in my pool, but since that same period of time, every water check I make, indicate chlorine is too high ???
    Other tests like PH, TA etc... look ok ! My water always look clear.
    thanks
    12' above ground pool install "inground" - hayward pro-lx serie sp-2295 pump - hayward vari-flo sp704 - 2 x 4' x 20' fafco solar bear panel
    for polar bear living north pole, Quebec city , Canada
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: no chlorine = too much chlorine
    What exactly is "too high"?
    Do you have tablets in a feeder or a floater?
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    and how are you testing for FC?
    I always used chlorine pucks. 1 in the skimmer and 1 on the floting device, but since 3-4 weeks, I stopped using chlorine pucks because chlorine was like I said too high, I don't know exactly how much !! on the strip test, it's have the exact color for "spa high" and with the other cheap test kit, again color is dark yellow, which is the highest color on the bottle color.
    Sorry for my ignorance, but I don't what FC mean !
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by frenchie
    Sorry about that. FC = free chlorine which is the good stuff that oxidizes the bad stuff.
    Disregard the test strip reading. Your other kit is an OTO chlorine test and should be able to at least tell you if you have some chlorine in the pool, though it does not differentiate between FC and TC (total chlorine). Take a read through this article in pool school: http://www.troublefreepool.com/pool-...ater_chemistry I would recommend you get a good test kit (see link in my sig...get the tf100). As you have suggested, chlorine does not "magically" regenerate, so not having chlorine in you pool means you are at risk for organisms multiplying.
    South Central NJ
    3,192
    The next questio that begs to be asked is what is CYA level of your water.
    Scott
    Owner of - PoolGuyNJ LLC
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes CYA is quite likely pretty high.
    Welcom to the forum. As you will hear again, it really is best to have a good test kit. Strips are very inaccuarate.
    Essential Links:
    I wanted to get that test kit, but way too expensive , especially here in canada. I bring a water sample to my hardware store who do the test for free to customers. I may take this too seriously, since my water have always been clear and nice. I will bring another sample before season's over.
    other topic, an update on my 2 fafco solar panels I installed this season work terrific ! I once reached 92 degrees, so very proud and satisfy with that project.
    thanks
