Thread: Help with new cleaner purchase
    Feb 2009
    Honolulu
    8
    I'm looking for your thoughts on what to get to replace my old Polaris 380 that has been in operation for 7 years of continuous use. More often than not, I find the 380 motionless and in need of a new part or disassembly to rehook a hose or two. I want to stick with the booster pump / cleaner combination and not plunge into the robot arena.
    My pool:
    20x40 with a 9 foot deep end
    Plaster surface
    Corner angles are 45 degrees except for the stairs section
    3/4 hp Polaris booster pump
    The pool collects many small leaves and approximately 20 larges leaves per day.
    Do I stick with the 380, upgrade to the 480, downgrade to the 280, or go with a totally different manufacturer?
    My order of priorities:
    1) Length of time required to clean the pool
    2) Depedability
    3) Price
    Thanks for your comments!
    Nov 2010
    Calera, Al
    271
    Re: Help with new cleaner purchase
    I have the Polaris 280, which IMHO is better than the 380. It uses gears inatead of belts to drive it and has far fewer problems from what I have read. It still uses the booster pump and probably the same wall fitting...
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Feb 2009
    Honolulu
    8
    Thanks ROB N. The 280 does have a lot of positive feedback on this site.
