Thread: Best brush for plaster?
    Jun 2011
    NW Florida
    57
    Non-marring of course (found out the hard way). Should it have all metal bristles, part, or all plastic?
    Thanks!
    Mike
    Commercial,100 K, Liquid chlorine, Indoor, Heated to 86 with Jandy Lite 2 gas heater, High-Rate Sand Triton TR-100 filters (3), 7.5 HP pump motor, IG, Plaster.
    Jesus is my Lifeguard!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Best brush for plaster?
    Brush recommendations:
    Nylon is for vinyl, fiberglass, tile, and plaster that is less than one year. (Plaster includes any exposed aggregate and marcite finish, btw!) Combo brushes are for older plaster. All stainless are for algae (very stubborn green algae and also the ONLY brush for black algae.)
    You CAN unscrew the Wall Whale from the nylon brush it comes with and screw it on a combo brush if your plaster is over a year old. Newer plaster is really too soft for anyting other than a nylon brush.
    You're done SLAMing when:
    Jun 2011
    NW Florida
    57
    Thanks for your great reply
