Thread: Great article on problems with chlorine and SWGs as solution
    May 2011
    Coral Springs, FL (near Ft. Lauderdale)
    93
    Article is in Wall Street Journal so unfortunately you need to be a subscriber to view it, but it discusses the high cost of maintaining a chlorine pool, the problems with the smell of chlorine, the irritated eyes, faded swimsuits, etc. and how SWGs are a great alternative. My favorite quote: "Traditional liquid and tablet chlorine costs up to $700 a year for a residential pool owner. Periodic so-called shock treatments to raise the chlorine level can be $150 and higher for a home pool, depending on pool size and use."
    Here's the link: http://online.wsj.com/article/SB1000142 ... %3Darticle
    I posted a link to TFP in the comments (which, by the way, can be read for free - very entertaining to see how many problem people have with their pool maintenance and how SwimSpray is a favored solution).
    15x30 inground concrete pool w/spa and spillover, all under screen enclosure
    Hayward C1200 StarClear Plus Cartridge Filter and Hayward Navigator V-Flex
    Jandy AquaPure 1400, Laars LX400 propane heater w/120 gal above-ground tank
    Jandy VS FloPro 2.7 HP Pump VSFHP270JEP; FlowVis FV-C Flow Meter
    Jandy iAquaLink and OneTouch controller w/PDA remotes; JVA for draining pool
    WestSidePool's Avatar
    Cincinnati, OH
    424
    Re: Great article on problems with chlorine and SWGs as solu
    I was reading most of the comments, and it sounds like a bunch of the people have been misinformed like most people who join the site.
    I also find it interesting in the small bit you can read, how they make it sound like having a SWG is different than just regular chlorine, when in fact its still a chlorine pool, you just don't have to manually add it.
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    The video is viewable for free.
    There's another post linking to this article, maybe the mods can merge the two. In the video the pool gal states that SWG actually is chlorine but it sounds like they gloss over that fact in the article maybe.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Feb 2009
    NW Chicago Suburb, IL
    75
    Here is the full article from Google cache. Really does make it seem like salt water pools are not chlorine pools.
    http://webcache.googleusercontent.com/s ... 39750.html
    15,000 Gallon IG 15x30 fiberglass
    CoverStar auto safety cover
    SWG Aqua PL-PLUS
    Cartridge Filter
    240,000 LXI Heater
    Aug 2007
    near the swamp
    806
    the comments on that article provided many laughs
    props to the poster who plugged this website!
