Thread: Pentair Whisperflo Lid Alignment?
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    I have a Pentair WF. There are alignment marks on the Lid. If I tighten it reasonably by hand, it doesn't come very close to alignment. I have air inthe basket and am trying to track it down. I was thinking of making a wrench or buying a wrench to tighten the lid. But I'm afraid to put that much pressure on the Volute.
    Do you guys get your lids aligned when closing?
    14x30 PebbleTec(Caribbean Blue) 12,000 Gals BORAX
    Pentair IntelliFlo <<>> Pentair FNS Plus DE
    Pentair 5G Intellibrite w/Intellibrite Controller
    ROME Solarium 125 Heat Pump
    Kreepy Krauly Classic <<>> Pentair 320 Feeder
    South Central NJ
    3,192
    Re: Pentair Whisperflo Lid Alignment?
    How much air?
    Does the pump seem to have trouble pulling prime?
    Scott
    Owner of - PoolGuyNJ LLC
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    A lot of air. It pulls prime but it could pull it faster in my opinion.
    I think I found the leak yesterday. I've gone through a lot of things looking for it since I bought the house in April. I used a stethoscope that I made to listen for vacuum leaks on my car and found the skimmer valve seems to be leaking on the connection closest to the ground. Good thing, is that in the meantime, all the seals got replaced everywhere on the suction side!
    I have some JB Water Weld to seal the connection up. Is that good for that purpose?
    Do check those drain plugs on the bottom of the pump basket housing. They can let in air that you don't see much in the lid.
    Skimmer valve? We just opened up a Jandy Neverlube valve body to find the larger o-ring was a little bit cracked. I read that this o-ring is to be lubed annually, I'm sure it never had been in 9 - 10 years. Silicone lube fixed it.
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    Quote Originally Posted by anonapersona
    I think I listened around that valve but now am not sure.
    I'll check that out, thanx!
    The Hurricane Irene is kinda ruining outside stuff today so don't know whether I'll get to the Water Weld or not. I'll see if I can catch it between bands of rain.
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    I believe it about the valves. All 3 of my suction valves had broken, flattened, hardened O-rings. Installed in 2007.
