Thread: Ocean water in a fresh water swimming pool
    I recently acquired a beachfront property in tropical Thailand with a swimming pool made of plaster. The pool is only 1 year old, and yet I already see some pop offs on the plaster surface. Furthermore, the pool has been filled using ocean water!
    When I spoke to the former owners, they told me that during the time they were building the pool, they couldn't secure fresh water to fill up the pool (as the property is in a remote island). So they decided to pump ocean water into the pool. And they have not replaced the water with fresh water since then. The water though is quite clear -- they have managed to filter it really well. But tastes a bit salty of course!
    So my question is, could using the ocean water in a swimming pool that is built to hold only fresh water adversely affect the pool plaster and cause the pop offs?
    In-ground vinyl 16x32, 17,500 gallons
    Sand filter, CircuPool RJ30 chlorine generator
    Jun 2011
    Northeast Ohio USA
    178
    Re: Ocean water in a fresh water swimming pool
    Welcome, and I am going to say, yes, that your on the right track with your thinking.
    http://www.troublefreepool.com/pool-...aster_start-up is one of the articles in pool school, and it specifically says no salt for the first 30 days, let alone ocean concentrations of salt. There are other articles on plaster as well that may shed some light on this. Specifically making sure the calcium levels are correct. There may be other things, as I am certainly no expert on this.
    honestly, I am not sure what is meant by pop-off, but I imagine the best thing to do at this point is to get the water chemistry in check, and then repair any visible damage as needed. Hopefully that will not be very hard, as it sound like you have a very nice set up there. Pictures are welcome.
    Vinyl In-Ground (vinyl) - about 21600 gallons (18x32 Grecian)
    Hayward DE (model 7220?) filter with Multiport valve
    Challenger Hi Flo Pump (3/4 HP)
    Intex SWG
    leaky/non-functioning Raypak Versa Natural Gas Heater *removed*
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Quote Originally Posted by h20
    I recently acquired a beachfront property in tropical Thailand.........
    Boy, if I had a dime every time I heard that I'd have........well, 1 dime.
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    Google (bottom left on page) has some interesting info:
    post32010.html#p32010
    seawater-pools-t9088.html
    Can you post a pic or ten for us?
    You're done SLAMing when:
    Quote Originally Posted by shortdogOH
    Thanks for the quick response! I really appreciate the input.
    The pop-offs I was describing are patches of plaster that cracked and popped off from the surface, so you have some sort of crater where the pop off occurred. Not sure but reading from some articles on plaster problems, I think what happened is something close to what is called delamination. Is this the
    Oops! Sent my message prematurely.
    Anyway, I just wanted to ask if how I described the pop-off makes any sense, and would the ocean water have caused the plaster to breakdown as such?
    I will post the water chemistry and photo soon!
