Results 1 to 11 of 11
Thread: High FC loss overnight!
    Aug 2011
    Raleigh area, NC
    13
    Morning!
    Thought I was doing great & decided to do OCLT last night. FC level went from 7ppm last night to 3 ppm this morning and CC=1ppm (it's been o or .5 all week) ugh...
    So I just shocked the pool according to the FC/CYA chart to get FC levels up to 12.
    FC: 3
    CC: 1
    pH: 7.5
    TA: 100
    CYA: 30ish
    Pool water looks & feels great, no slimy walls so I don't understand what happened. We've had company the past few days, so there have been extra people in the pool. My lowest FC read was 2.5 one afternoon, other than that it's been between 3-4 during the day and we bump to 7 at night.
    We are new pool owners (I posted last week in Just Getting Started to make sure we were starting off on the right path) and have used BBB method from day 1.
    Is this something I should expect after rigorous use? Is there a way for me to be more proactive? I just cringed this morning as I poured all that bleach (250 oz) into the pool.
    As always...you guys rock! Thanks for all your help.
    Robin
    14K; Hayward Pro-Series sand filter; 24' AG; 1.5 hp/ 2spd Power Flo Matrix Pump
    South Central NJ
    3,192
    Re: High FC loss overnight!
    Shock the pool. The CCs are too high.
    Scott
    Owner of - PoolGuyNJ LLC
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,989
    Are you sure nobody snuck out for a midnight skinny dip?
    Aug 2011
    Raleigh area, NC
    13
    Tested about an hour after shocking:
    FC: 12.5
    pH: high (possibly 8)
    TA: 90
    CYA: 30-40 (seems higher today than yesterday, we added CYA Sunday night...)
    I did not do CC test. According to Pool School I should shock at least twice, so I plan on doing that again tonight. I'll perform all tests again prior to shocking.
    Should I be concerned about high pH reading? I was reading around the site and consensus seems to be no- pH tests are inaccurate during shock levels.
    Any reason the kids shouldn't use pool this afternoon- I shocked around 9am?
    Robin
    WestSidePool's Avatar
    Cincinnati, OH
    424
    To be proactive, add enough chlorine before your swim party to keep it above minimum, and test during if you have to.
    Keep in mind, shocking is a process. You have to keep your chlorine level up at shock level until you pass the three tests, otherwise your just wasting chlorine.
    -CC is 0.5 or lower
    -An overnight FC loss test shows a loss of 1.0 ppm or less
    -And the water is clear.
    It's safe to swim while shocking as long as the shock levels are at the recommended level with your CYA.
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    18,989
    pH can read wrong with high FC levels. Ignore it for now.
    Aug 2011
    Raleigh area, NC
    13
    Thanks for the feedback. 1 pm test results show :
    FC 11.5
    CC .5
    pH 7.5- 7.8
    I feel better now. I did vacuum and backwash. I'm thinking that may also impact results but am not sure.
    Robin
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by rme
    CYA can take up to a week to show up in the test. I would use how much you think you put in to calculate your shock level for now. Test CYA again this coming Sunday/Monday and then adjust your FC levels to that.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Now is the time to add .5ppm chlorine to raise it back to shock level.
    Falling below minimum even ONCE can cause this (happened to me about two weeks ago). The prevention is to never let it get that low, if you have to add a little more for high bathing load do it. It sounds like you caught it early enough to make it a one day shock process. But don't let it fall below shock (12ppm). Maintain shock level through today, do an OCLT with CC tomorrow morning and it will likely be all done. If not, one more day of maintaining won't hurt.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    I'll bet the pool was digesting sunscreen and that is what consumed the chlorine.
    Aug 2011
    Raleigh area, NC
    13
    Quote Originally Posted by frogabog
    I did not realize that when shocking I had to maintain the shock level throughout the whole day or time frame. I'll definitely keep that in mind from now on. For now I think the problem's been resolved.
    Thanks for everyone's help during my crisis!
    Robin
