Results 1 to 7 of 7
Thread: Our pool wont hold free chlorine
    Jul 2011
    Las vegas, NV
    3
    We run our salt water pool generator for 4 hrs like it says to in the manual. We have had our pool open for 6 weeks now and can seem to keep all our levels right except that there is never any free chlorine or any of the other chlorine unless we add chlorine to the pool ourselves. The pool is always cloudy (not green). We have tried running the generator for 6 hrs and still nothing. Our salt levels are where they are suppose to be, and my husband made sure the genrator and filter were clean and working. To me the water is always dirty as if the filter isnt working but why can't we get any chlorine in the pool or to stay once we add it???
    Frustrated pool mom !
    INTEX ABOVE GROUND POOL 3490 gals
    Krystal Clear Model 637R Filter Pump AND
    krystal Clear Saltwater System Model CS8110
    Jul 2011
    Central Califorina
    208
    Re: Our pool wont hold free chlorine
    Sounds like you need to shock your pool. Hard to tell exactly what you need to do without accurate test results.
    Did you add CYA as well as salt?
    I have a 2000 gallon pool with intex sand filter and SWCG. Upgrading your pump/filter would be a wise investment.
    My CYA is at 70 ppm and I run my SWCG 2 hours a day with the pump on 4 hours and my water is crystal clear.
    3500 gallon 14x42 Intex Ultra Frame
    1/2 HP Intex 1600 sand filter/pump - Intex SWCG
    Two 4x20 Fafco solar panels.
    Taylor K-2006
    Marquis spirit hot tub - Grill Dome ceramic grill/smoker
    30,416
    Reading Pool School will help you understand that chlorine is consumed by organics (algae) in your pool and that's almost surely your issue.
    However, a complete set of test results is about the only way to get you started clearing your pool.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Please post a complete set of test results and we can help you pinpoint the problem.
    Love TFP? Become a
    TFP Supporter!
    CYA (stabilizer) helps hold the chlorine that is created. Probably low, your testing will show if that is the culprit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    I agree, we need to know if you have any CYA in the pool. Without it, with Vegas sun and heat, you'd be hard-pressed to keep up with demand pouring in bleach all day. As you may have learned already.
    If you don't already have a good test kit, get one. I recommend the TF100 with a speedstir. It's what I use, makes testing fast, easy, and accurate. With your own test results, pool calculator, and maybe some advice from here, you'll be able to have perfect water that will be the envy of the neighborhood.
    WestSidePool's Avatar
    Cincinnati, OH
    424
    Also, you should be running your SWG based on chlorine test results. The manual really doesn't know what your pool is doing and running it 4 hours may or may not be long enough. Also the % may or may not be high enough to keep up with the chlorine demand.
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
