Results 1 to 19 of 19
Thread: Hayward Super Pump won't turn on
    Shpigford's Avatar
    Apr 2011
    Birmingham, AL
    50
    I vacuumed the pool without issue, then turned off the pump to clean out the pump basket. I then closed it back up and tried to turn the pump back on and just got a feint hum for a 10 seconds or so, then it went completely silent.
    Any ideas what might be going on? It's a Hayward 3/4 HP Super Pump.
    22,000 gallon vinyl in ground with Hayward S244T sand filter and Hayward 3/4 hp Super Pump.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Hayward Super Pump won't turn on
    With the power removed from the pump and the water valves off take out your leaf basket and see if you can reach into the impeller area and see if the impeller (pump vanes) is free/moving?
    Shpigford's Avatar
    Apr 2011
    Birmingham, AL
    50
    Quote Originally Posted by linen
    I was able to turn the impeller, but how "free" is it supposed to be? It didn't just readily spin with the flick of my finger. It only turned if I pushed on it.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    It won't spin freely, but it should move 360 degrees without getting hung up.
    Shpigford's Avatar
    Apr 2011
    Birmingham, AL
    50
    Yeah, it does.
    So...still not sure what might be going on.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Have tried to start it since you spun the impeller? If it does not start, does it still hum?
    Shpigford's Avatar
    Apr 2011
    Birmingham, AL
    50
    Yeah. It's humming again, but doesn't start.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Try this: when it is humming give the motor housing a rap or two with a piece of wood/hammer handle and see if it starts.
    Shpigford's Avatar
    Apr 2011
    Birmingham, AL
    50
    Still no go. Tried a few times and the humming eventually stops after I've smacked it, but I can't tell if the humming stops because I'm hitting it or because it just shuts itself off.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    My experience has been (not with this particular motor, but with other motors), if the shaft and impeller move freely, and the motor hums but won't spin up, then it might be the start capacitor. Hopefully someone with this motor/knowledge of this motor can tell you where it is.
    It's most likely the capacitor. Replace that to see if it works. The start capacitor is under the back motor cover. If you have a run capacitor, then it is mounted on top of the motor.
    What does the motor label say for "Type"?
    Support the site
    There is also a set of contact points on a centrifugal for the starter circuit. They might need cleaning or stuck partially open.
    Glenn - Pickering, Ontario
    Circa 1980 Vinyl In-ground 80,000 Ltrs. ~ K2006 Kit ~ Hayward Pump/Navigator/Sand Filter ~ Raypak 255 Gas Heater
    Shpigford's Avatar
    Apr 2011
    Birmingham, AL
    50
    Quote Originally Posted by JamesW
    It says "UAC"
    Shpigford's Avatar
    Apr 2011
    Birmingham, AL
    50
    Also, how do I know if the capacitor is bad? Here's a photo under the proverbial hood of my pump:
    Quote Originally Posted by Shpigford
    motor shop or electrician should be able to test it,,, just happened to me
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    heat siphon heat pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If you have a multimeter: http://www.stpats.com/ElectricMotorR...#testcapacitor
    You can test it with a multimeter or you can just replace it to see it that solves the problem. You could also clean the contacts of the switch (center of picture) to see if that helps.
    I think that type “UAC” means capacitor start/capacitor run. The start capacitor is the black cylinder shown in the picture. Is there also a larger Run capacitor mounted on the outside of the motor?
    Support the site
    TheLoneHoot's Avatar
    May 2013
    JAX, FL
    15
    Hayward Super Pump won't turn on - DIFFERENT GUY, SAME PROBL
    I'm having the same problem, so I've been watching this thread (and others). I got a new capacitor (just a few minutes ago actually) and installed it. The pump is still making a loud humming noise and won't run. the impeller is totally cleared of debris and spins easily. The pump/motor is only about 2 years old.
    Any thoughts on what else it could be?
    My pool is turning green and thanks to a recent monsoon is full of sand and other particulate matter.
    -Austin
    15,000 gal (I think) sort of "hexagonal dogbone" shaped pool built in 1996
    Hayward Super Pump, Cartridge type filter, 1HP motor (new as of 31 August 2013)
    Hayward Aquadroid cleaner (original model) totally rebuilt except for shell in last year or so
    [center:1mx1gn4d]Pool (p?l): n. a hole in the ground into which one throws vast sums of money[/center:1mx1gn4d]
    [center:1mx1gn4d]Since I&#39;m always asked:[/center:1mx1gn4d]
    [center:1mx1gn4d]* * * * * * * * * * * *How&#39;s the weather in FL?[/center:1mx1gn4d]
    May 2013
    JAX, FL
    15
    Problem resolved. New pump motor.
    $256 - ouch.
    Cest la vie...
    -Austin
